跳转到主内容
加入维修社区 - 创建账户
HTC One X Antenna Replacement
你所需要的
  1. HTC One X Antenna Replacement, Squeeze Test: 步骤 1 中的图像 1,1
    • Before replacement of the antenna, carry out the squeeze test.
    • Gently squeeze your device between the camera lens and the volume button. This should temporarily reconnect the antenna if it's loose.
    • If the squeeze test doesn't reconnect your wi-fi/bluetooth then move to step 2
    询问修复机器人
    添加评论
  2. HTC One X Antenna Replacement, Remove SIM card slot: 步骤 2 中的图像 1,1
    • Insert a safety pin, or other small object into the narrow aperture next to the Sim Card Slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
    询问修复机器人
    添加评论
  3. HTC One X Antenna Replacement, Remove front panel: 步骤 3 中的图像 1,2 HTC One X Antenna Replacement, Remove front panel: 步骤 3 中的图像 2,2
    • Use a plastic opening tool, and carefully insert it between the display and rear panel. Separate the two parts.
    • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
    • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage or bodily harm.
    • Set aside the rear panel for now
    询问修复机器人
    添加评论
  4. HTC One X Antenna Replacement, Replace antenna: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Once the rear panel is separated from the front panel, remove the antenna using tweezers.
    • The antenna is located on the right hand side of the front panel as indicated in the image.
    • Replace and reconnect the new antenna in the same position as the faulty one you just removed. Remember to place it underneath the metal supports on the board.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Blain Abebe
于09/22/14注册
769 声望
创作了3篇指南
团队
USF Tampa, Team 4-3, Brown Fall 2014 USF Tampa, Team 4-3, Brown Fall 2014 的会员
USFT-BROWN-F14S4G3
3 名成员
创作了26篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 30
总计 9,832
