跳转到主内容
加入维修社区 - 创建账户
HTC One Max Rear Facing Camera Replacement
你所需要的
  1. HTC One Max Rear Facing Camera Replacement, Back Case: 步骤 1 中的图像 1,1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
    询问修复机器人
    添加评论
  2. HTC One Max Rear Facing Camera Replacement: 步骤 2 中的图像 1,2 HTC One Max Rear Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
    询问修复机器人
    添加评论
  3. HTC One Max Rear Facing Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
    添加评论
  4. HTC One Max Rear Facing Camera Replacement: 步骤 4 中的图像 1,2 HTC One Max Rear Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Use the small plastic opening tool to pry between the screen and the rear case.
    询问修复机器人
    添加评论
  5. HTC One Max Rear Facing Camera Replacement, Fingerprint Sensor: 步骤 5 中的图像 1,2 HTC One Max Rear Facing Camera Replacement, Fingerprint Sensor: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
    询问修复机器人
    添加评论
  6. HTC One Max Rear Facing Camera Replacement, Motherboard: 步骤 6 中的图像 1,2 HTC One Max Rear Facing Camera Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
    询问修复机器人
    添加评论
  7. HTC One Max Rear Facing Camera Replacement: 步骤 7 中的图像 1,2 HTC One Max Rear Facing Camera Replacement: 步骤 7 中的图像 2,2
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
    添加评论
  8. HTC One Max Rear Facing Camera Replacement: 步骤 8 中的图像 1,1
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
    询问修复机器人
    添加评论
  9. HTC One Max Rear Facing Camera Replacement: 步骤 9 中的图像 1,3 HTC One Max Rear Facing Camera Replacement: 步骤 9 中的图像 2,3 HTC One Max Rear Facing Camera Replacement: 步骤 9 中的图像 3,3
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
    询问修复机器人
    添加评论
  10. HTC One Max Rear Facing Camera Replacement: 步骤 10 中的图像 1,3 HTC One Max Rear Facing Camera Replacement: 步骤 10 中的图像 2,3 HTC One Max Rear Facing Camera Replacement: 步骤 10 中的图像 3,3
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
    添加评论
  11. HTC One Max Rear Facing Camera Replacement: 步骤 11 中的图像 1,2 HTC One Max Rear Facing Camera Replacement: 步骤 11 中的图像 2,2
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
    询问修复机器人
    添加评论
  12. HTC One Max Rear Facing Camera Replacement, IR Blaster: 步骤 12 中的图像 1,1
    • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
    询问修复机器人
    添加评论
  13. HTC One Max Rear Facing Camera Replacement: 步骤 13 中的图像 1,1
    • Pick up and set aside vibrator, do not disconnect.
    询问修复机器人
    添加评论
  14. HTC One Max Rear Facing Camera Replacement: 步骤 14 中的图像 1,1
    • Pull out ribbon cable.
    • Peel back infrared sensor.
    添加评论
  15. HTC One Max Rear Facing Camera Replacement, Rear Facing Camera: 步骤 15 中的图像 1,2 HTC One Max Rear Facing Camera Replacement, Rear Facing Camera: 步骤 15 中的图像 2,2
    • Lift the secondary motherboard with the camera attached.
    询问修复机器人
    添加评论
  16. HTC One Max Rear Facing Camera Replacement: 步骤 16 中的图像 1,3 HTC One Max Rear Facing Camera Replacement: 步骤 16 中的图像 2,3 HTC One Max Rear Facing Camera Replacement: 步骤 16 中的图像 3,3
    • Use a plastic opening tool to disconnect the camera ribbon cable.
    • Remove rear camera.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
Andrew Keller
于09/23/14注册
1,131 声望
创作了5篇指南
团队
USF Tampa, Team 11-3, Blackwell Fall 2014 USF Tampa, Team 11-3, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S11G3
4 名成员
创作了14篇指南
1指南评论
so..which one do i have to buy?
the Phillips #00 or the #000? the steps say one thing, the required tools section says another.
thanks in advance
alberto rivera - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 34
总计 8,514
