跳转到主内容
加入维修社区 - 创建账户
HTC Incredible 2 Power Button Replacement
你所需要的
  1. HTC Incredible 2 Power Button Replacement, Disassembling HTC Incredible 2 Back Panel: 步骤 1 中的图像 1,2 HTC Incredible 2 Power Button Replacement, Disassembling HTC Incredible 2 Back Panel: 步骤 1 中的图像 2,2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
    询问修复机器人
    添加评论
  2. HTC Incredible 2 Power Button Replacement: 步骤 2 中的图像 1,1
    • Remove the rear panel from the phone.
    询问修复机器人
    添加评论
  3. HTC Incredible 2 Power Button Replacement, Battery: 步骤 3 中的图像 1,1
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
    询问修复机器人
    添加评论
  4. HTC Incredible 2 Power Button Replacement: 步骤 4 中的图像 1,2 HTC Incredible 2 Power Button Replacement: 步骤 4 中的图像 2,2
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
    询问修复机器人
    添加评论
  5. HTC Incredible 2 Power Button Replacement, SIM Card: 步骤 5 中的图像 1,2 HTC Incredible 2 Power Button Replacement, SIM Card: 步骤 5 中的图像 2,2
    • Apply pressure with your fingertip to the pressure clip beneath the SIM card.
    • While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
    询问修复机器人
    添加评论
  6. HTC Incredible 2 Power Button Replacement: 步骤 6 中的图像 1,2 HTC Incredible 2 Power Button Replacement: 步骤 6 中的图像 2,2
    • Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card.
    询问修复机器人
    添加评论
  7. HTC Incredible 2 Power Button Replacement, Mid Panel: 步骤 7 中的图像 1,1
    • Remove the seven 1.42 mm Torx T5 screws
    询问修复机器人
    添加评论
  8. HTC Incredible 2 Power Button Replacement: 步骤 8 中的图像 1,2 HTC Incredible 2 Power Button Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to run along the phone's side and lever mid panel upward.
    • Apply minimal pressure as the mid panel is very delicate.
    询问修复机器人
    添加评论
  9. HTC Incredible 2 Power Button Replacement: 步骤 9 中的图像 1,1
    • Gently grasp and carefully lift mid panel up and away from the device with your fingers.
    询问修复机器人
    添加评论
  10. HTC Incredible 2 Power Button Replacement, Power Button: 步骤 10 中的图像 1,3 HTC Incredible 2 Power Button Replacement, Power Button: 步骤 10 中的图像 2,3 HTC Incredible 2 Power Button Replacement, Power Button: 步骤 10 中的图像 3,3
    • Firmly grasp the power button, located on the upper right corner of the mid panel, and gently lift it up and off the mid panel.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014 的会员
CPSU-AMIDO-S14S11G53
5 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,083
