跳转到主内容
加入维修社区 - 创建账户
HTC Incredible 2 Micro SD Card Replacement
  1. HTC Incredible 2  Micro SD Card Replacement, Disassembling HTC Incredible 2 Back Panel: 步骤 1 中的图像 1,2 HTC Incredible 2  Micro SD Card Replacement, Disassembling HTC Incredible 2 Back Panel: 步骤 1 中的图像 2,2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
    询问修复机器人
    添加评论
  2. HTC Incredible 2  Micro SD Card Replacement: 步骤 2 中的图像 1,1
    • Remove the rear panel from the phone.
    询问修复机器人
    添加评论
  3. HTC Incredible 2  Micro SD Card Replacement, Micro SD Card: 步骤 3 中的图像 1,2 HTC Incredible 2  Micro SD Card Replacement, Micro SD Card: 步骤 3 中的图像 2,2
    • Use your fingertip to push inward on the SD card until you hear a click.
    询问修复机器人
    添加评论
  4. HTC Incredible 2  Micro SD Card Replacement: 步骤 4 中的图像 1,3 HTC Incredible 2  Micro SD Card Replacement: 步骤 4 中的图像 2,3 HTC Incredible 2  Micro SD Card Replacement: 步骤 4 中的图像 3,3
    • Remove your finger. The SD card is no longer being held in place.
    • Grasp it with two fingers and pull it towards you to remove it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Ka Tong
于04/26/14注册
131 声望
撰写一个指南
团队
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014 的会员
CPSU-AMIDO-S14S11G53
5 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 40
总计 620
