跳转到主内容
加入维修社区 - 创建账户
HTC Hero Trackball Replacement
你所需要的
  1. HTC Hero Trackball Replacement, Back Case: 步骤 1 中的图像 1,1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    询问修复机器人
    添加评论
  2. HTC Hero Trackball Replacement: 步骤 2 中的图像 1,1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    询问修复机器人
    添加评论
  3. HTC Hero Trackball Replacement: 步骤 3 中的图像 1,1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    询问修复机器人
    添加评论
  4. HTC Hero Trackball Replacement: 步骤 4 中的图像 1,2 HTC Hero Trackball Replacement: 步骤 4 中的图像 2,2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    询问修复机器人
    添加评论
  5. HTC Hero Trackball Replacement, Trackball: 步骤 5 中的图像 1,2 HTC Hero Trackball Replacement, Trackball: 步骤 5 中的图像 2,2
    • Remove the two screws near the bottom of the motherboard with a Phillips head screwdriver.
    询问修复机器人
    添加评论
  6. HTC Hero Trackball Replacement: 步骤 6 中的图像 1,2 HTC Hero Trackball Replacement: 步骤 6 中的图像 2,2
    • Gently pull off the ribbons holding the sides of the motherboard to the front enclosure.
    询问修复机器人
    添加评论
  7. HTC Hero Trackball Replacement: 步骤 7 中的图像 1,2 HTC Hero Trackball Replacement: 步骤 7 中的图像 2,2
    • Remove the motherboard from within the front enclosure.
    • Be careful when pulling the ribbons off the motherboard as they may rip or break.
    询问修复机器人
    添加评论
  8. HTC Hero Trackball Replacement: 步骤 8 中的图像 1,2 HTC Hero Trackball Replacement: 步骤 8 中的图像 2,2
    • Tilt the inside of the front enclosure towards your cupped palm to remove the trackball and it's enclosure will fall out.
    询问修复机器人
    添加评论
  9. HTC Hero Trackball Replacement: 步骤 9 中的图像 1,3 HTC Hero Trackball Replacement: 步骤 9 中的图像 2,3 HTC Hero Trackball Replacement: 步骤 9 中的图像 3,3
    • Position the phone off of the edge of the table and insert the replacement part by inserting the bevel then the trackball into the hole.
    • Make sure the two plastic pins on the trackball bevel are oriented horizontally.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Max Brown
于01/23/12注册
139 声望
创作了4篇指南
团队
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G26
5 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 36
总计 1,902
