跳转到主内容
加入维修社区 - 创建账户
HTC HD2 Camera Replacement
你所需要的
    1. HTC HD2 Camera Replacement, Battery: 步骤 1 中的图像 1,1
      • Carefully pull the rear cover from the back of the phone.
      • Place a finger beneath the small lip on the left side of the battery.
      询问修复机器人
      添加评论
    2. HTC HD2 Camera Replacement: 步骤 2 中的图像 1,2 HTC HD2 Camera Replacement: 步骤 2 中的图像 2,2
      • Lay the phone down on it's screen.
      • Lift up on the lip and pull the battery from the phone.
      询问修复机器人
      添加评论
    1. HTC HD2 Camera Replacement, Midframe: 步骤 3 中的图像 1,2 HTC HD2 Camera Replacement, Midframe: 步骤 3 中的图像 2,2
      • Remove the four black 3.5mm T5 screws from the back of the phone.
      询问修复机器人
      添加评论
    2. HTC HD2 Camera Replacement: 步骤 4 中的图像 1,2 HTC HD2 Camera Replacement: 步骤 4 中的图像 2,2
      • Insert the flat end of a spudger between the midframe and the display.
      • Slide the spudger along the seam between the frame and the display.
      • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
      • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
      • As it releases, pull the midframe away from the phone.
      • The volume control tab may fall off during removal. It can be easily reattached.
      询问修复机器人
      添加评论
    1. HTC HD2 Camera Replacement, Camera: 步骤 5 中的图像 1,3 HTC HD2 Camera Replacement, Camera: 步骤 5 中的图像 2,3 HTC HD2 Camera Replacement, Camera: 步骤 5 中的图像 3,3
      • Disconnect the flash cable from its socket in the bottom of the motherboard.
      • Carefully pull the cable from its groove in the frame, working your way back to the camera.
      询问修复机器人
      添加评论
    2. HTC HD2 Camera Replacement: 步骤 6 中的图像 1,3 HTC HD2 Camera Replacement: 步骤 6 中的图像 2,3 HTC HD2 Camera Replacement: 步骤 6 中的图像 3,3
      • Pull the camera flash and cover off of the board.
      • You may need to peel back the sticker that sits behind the battery.
      • Work carefully. Excessive force can damage the camera or motherboard.
      询问修复机器人
      添加评论
    3. HTC HD2 Camera Replacement: 步骤 7 中的图像 1,1
      在这个步骤中使用的工具:
      • Around the camera is a thin shielding. Remove it with tweezers.
      • Using tweezers, remove the primary camera.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 24-55, Amido Spring 2011 Cal Poly, Team 24-55, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G55
5 名成员
创作了72篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 39
总计 8,439
