简介
In this guide, we will be removing and replacing the HTC EXCA100's screen
你所需要的
Remove the rubber screw covers. If needed, use a thin object to help pry them off. There should be two of them on top of the phone. Skip this step if already removed.
Pry loose the metal cover near the camera lens.
On the left side of the phone, there are three copper colored clips.
Unclip the bottom clip, thread the middle one through the logic board, and pull the top one out gently.
You can then lift the logic board out of the phone.
Do this at an angle, lifting the side to the right of the SIM card instructions.
Remove the metal frame. Slip out the copper clips still attached to the bottom frame from the frame carefully.
