简介
The motherboard is the main component of your device and is responsible for processing data and connecting the hardware. If your HTC Excalibur has experienced a malfunction like continuous crashes, failure to reboot, or it's unresponsive, this guide is here to help you go through the step-by-step process to replace your motherboard. Be careful while working with the device and avoid damaging the components of the device.
你所需要的
Remove the rubber screw covers. If needed, use a thin object to help pry them off. There should be two of them on top of the phone. Skip this step if already removed.
Pry loose the metal cover near the camera lens.
On the left side of the phone, there are three copper colored clips.
Unclip the bottom clip, thread the middle one through the logic board, and pull the top one out gently.
You can then lift the logic board out of the phone.
Do this at an angle, lifting the side to the right of the SIM card instructions.
另外一个人完成了本指南。
