跳转到主内容
加入维修社区 - 创建账户
HTC Droid DNA Rear-Facing Camera Replacement
你所需要的
  1. HTC Droid DNA Rear-Facing Camera Replacement, Remove the SIM Card Tray: 步骤 1 中的图像 1,1
    • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
    询问修复机器人
    添加评论
  2. HTC Droid DNA Rear-Facing Camera Replacement, Removing the SIM Card Tray: 步骤 2 中的图像 1,2 HTC Droid DNA Rear-Facing Camera Replacement, Removing the SIM Card Tray: 步骤 2 中的图像 2,2
    • Pull out the SIM Card Tray with your fingers.
    询问修复机器人
    添加评论
  3. HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Phone Casing: 步骤 3 中的图像 1,2 HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Phone Casing: 步骤 3 中的图像 2,2
    • Make sure the USB cover on the bottom of the phone is removed first.
    • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
    询问修复机器人
    添加评论
  4. HTC Droid DNA Rear-Facing Camera Replacement, Pull the Casing Apart: 步骤 4 中的图像 1,1
    • Slowly pull the panel apart from the back of the phone.
    • Apply a moderate force to pry the panel from the back of the phone.
    询问修复机器人
    添加评论
  5. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Black Tape: 步骤 5 中的图像 1,1
    • Set the device down so that the bottom of the phone is facing to the right.
    • Gently take off the piece of black tape surrounding the motherboard.
    • Be careful not to rip the tape.
    添加评论
  6. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Yellow Tape: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
    添加评论
  7. HTC Droid DNA Rear-Facing Camera Replacement: 步骤 7 中的图像 1,1
    • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
    • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
    询问修复机器人
    添加评论
  8. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Void Screw: 步骤 8 中的图像 1,1
    • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
    添加评论
  9. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Screw Retaining Bracket: 步骤 9 中的图像 1,1
    • Rotate your phone back 90 Degrees counter-clockwise.
    • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
    询问修复机器人
    添加评论
  10. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Connector Screws: 步骤 10 中的图像 1,1
    • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
    询问修复机器人
    添加评论
  11. HTC Droid DNA Rear-Facing Camera Replacement, Unfasten the Connectors: 步骤 11 中的图像 1,2 HTC Droid DNA Rear-Facing Camera Replacement, Unfasten the Connectors: 步骤 11 中的图像 2,2
    • Use your pry tool to unfasten the connectors on both sides of the motherboard.
    • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
    询问修复机器人
    添加评论
  12. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Yellow Tape: 步骤 12 中的图像 1,1
    • Use your tweezers to remove the two pieces of yellow tape shown.
    询问修复机器人
    添加评论
  13. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 步骤 13 中的图像 1,2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 步骤 13 中的图像 2,2
    • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
    询问修复机器人
    添加评论
  14. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: 步骤 14 中的图像 1,1
    • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cable of the Connector.
    询问修复机器人
    添加评论
  15. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 步骤 15 中的图像 1,2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 步骤 15 中的图像 2,2
    • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
    询问修复机器人
    添加评论
  16. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: 步骤 16 中的图像 1,1
    • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cables for the Connector.
    询问修复机器人
    添加评论
  17. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 步骤 17 中的图像 1,2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 步骤 17 中的图像 2,2
    • Rotate the phone 180 degrees.
    • Use your tweezers to gently snap up the white board on the top left of the motherboard.
    询问修复机器人
    添加评论
  18. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: 步骤 18 中的图像 1,1
    • Use your tweezers to disconnect the cable on the top left of the motherboard.
    询问修复机器人
    添加评论
  19. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the Black Board: 步骤 19 中的图像 1,2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the Black Board: 步骤 19 中的图像 2,2
    • Use your tweezers to gently snap up the black board on the top left of the motherboard.
    询问修复机器人
    添加评论
  20. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Small Ribbon Connector: 步骤 20 中的图像 1,1
    • Use your tweezers to gently remove the yellow connector on the top left of the phone.
    询问修复机器人
    添加评论
  21. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Black Wire: 步骤 21 中的图像 1,1
    • Remove the long black wire on the left of the motherboard.
    询问修复机器人
    添加评论
  22. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Two Black Wires: 步骤 22 中的图像 1,1
    • Reorient the phone so that the green camera board is farthest from you.
    • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
    添加评论
  23. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Screws: 步骤 23 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
    询问修复机器人
    添加评论
  24. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Motherboard: 步骤 24 中的图像 1,2 HTC Droid DNA Rear-Facing Camera Replacement, Remove the Motherboard: 步骤 24 中的图像 2,2
    • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
    询问修复机器人
    添加评论
  25. HTC Droid DNA Rear-Facing Camera Replacement, Remove Screws: 步骤 25 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the two 2.1mm screws on the top of the camera board.
    询问修复机器人
    添加评论
  26. HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Adhesive: 步骤 26 中的图像 1,2 HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Adhesive: 步骤 26 中的图像 2,2
    • Use the pry tool along the bottom and sides of the camera board to loosen the adhesive.
    • The power button and headphone jack need to be carefully removed with the camera board or they could snap off of the camera board.
    询问修复机器人
    添加评论
  27. HTC Droid DNA Rear-Facing Camera Replacement, Remove Camera Board: 步骤 27 中的图像 1,1
    • Slowly lift the camera board up and work on removing the remaining adhesive. You can then take the camera board off of the phone.
    询问修复机器人
    添加评论
  28. HTC Droid DNA Rear-Facing Camera Replacement, Remove Yellow Tape: 步骤 28 中的图像 1,2 HTC Droid DNA Rear-Facing Camera Replacement, Remove Yellow Tape: 步骤 28 中的图像 2,2
    在这个步骤中使用的工具:
    • Use your tweezers to gently pull off the two pieces of yellow tape in the center of the camera board.
    询问修复机器人
    添加评论
  29. HTC Droid DNA Rear-Facing Camera Replacement, White Connector Clip: 步骤 29 中的图像 1,2 HTC Droid DNA Rear-Facing Camera Replacement, White Connector Clip: 步骤 29 中的图像 2,2
    • Use your tweezers to gently flip the white connector board into the upright position.
    询问修复机器人
    添加评论
  30. HTC Droid DNA Rear-Facing Camera Replacement, Remove Rear-Facing Camera: 步骤 30 中的图像 1,1
    • Use your tweezers to remove the rear-facing camera from the camera board.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 4-43, Amido Fall 2014 Cal Poly, Team 4-43, Amido Fall 2014 的会员
CPSU-AMIDO-F14S4G43
4 名成员
创作了19篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 22
总计 1,340
