跳转到主内容
加入维修社区 - 创建账户
HTC Amaze Front Facing Camera Replacement
你所需要的
  1. HTC Amaze Front Facing Camera Replacement, Battery: 步骤 1 中的图像 1,2 HTC Amaze Front Facing Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
    添加评论
  2. HTC Amaze Front Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Once you locate the battery, look for a notch below it.
    • Gently insert your fingernails into the notch.
    • Lift the battery out of its recess.
    询问修复机器人
    添加评论
  3. HTC Amaze Front Facing Camera Replacement, HTC Amaze Back Panel Disassembly: 步骤 3 中的图像 1,3 HTC Amaze Front Facing Camera Replacement, HTC Amaze Back Panel Disassembly: 步骤 3 中的图像 2,3 HTC Amaze Front Facing Camera Replacement, HTC Amaze Back Panel Disassembly: 步骤 3 中的图像 3,3
    • Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
    • One of the Screws may have a tape attached to it that says void. Removing this screw will void the devices warranty.
    询问修复机器人
    添加评论
  4. HTC Amaze Front Facing Camera Replacement: 步骤 4 中的图像 1,3 HTC Amaze Front Facing Camera Replacement: 步骤 4 中的图像 2,3 HTC Amaze Front Facing Camera Replacement: 步骤 4 中的图像 3,3
    • Proceed to remove the back housing by using the spudger to gently unclip each clip holding the back housing in place and then lift the outer edges of the back housing
    • If you're having trouble opening the back try using the spudger to gently pry all around the panel before you attempt to remove it.
    询问修复机器人
    添加评论
  5. HTC Amaze Front Facing Camera Replacement: 步骤 5 中的图像 1,2 HTC Amaze Front Facing Camera Replacement: 步骤 5 中的图像 2,2
    • Now simply remove the back panel by gently pulling. This will make it easier to access the devices internal components.
    询问修复机器人
    添加评论
  6. HTC Amaze Front Facing Camera Replacement, Motherboard: 步骤 6 中的图像 1,3 HTC Amaze Front Facing Camera Replacement, Motherboard: 步骤 6 中的图像 2,3 HTC Amaze Front Facing Camera Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Locate and remove the Phillips J000 screw.
    询问修复机器人
    添加评论
  7. HTC Amaze Front Facing Camera Replacement: 步骤 7 中的图像 1,2 HTC Amaze Front Facing Camera Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the power supply from the motherboard by gently pulling the end of the black wire with the precision tweezers.
    询问修复机器人
    添加评论
  8. HTC Amaze Front Facing Camera Replacement: 步骤 8 中的图像 1,3 HTC Amaze Front Facing Camera Replacement: 步骤 8 中的图像 2,3 HTC Amaze Front Facing Camera Replacement: 步骤 8 中的图像 3,3
    • First, gently lift the black strip by pulling. It will take a little force and then it will disconnect.
    • Next remove the yellow mylar tape using the precision tweezers.
    询问修复机器人
    添加评论
  9. HTC Amaze Front Facing Camera Replacement: 步骤 9 中的图像 1,3 HTC Amaze Front Facing Camera Replacement: 步骤 9 中的图像 2,3 HTC Amaze Front Facing Camera Replacement: 步骤 9 中的图像 3,3
    • Remove the jawbone connector that was under the mylar tape by gently pulling with the precision tweezers.
    • Now gently pull the motherboard away from its housing. You'll now have access to the bottom side of the motherboard.
    询问修复机器人
    添加评论
  10. HTC Amaze Front Facing Camera Replacement: 步骤 10 中的图像 1,3 HTC Amaze Front Facing Camera Replacement: 步骤 10 中的图像 2,3 HTC Amaze Front Facing Camera Replacement: 步骤 10 中的图像 3,3
    • Locate a second jawbone connector covered by mylar tape at the bottom of the back of the motherboard.
    • Remove the tape by pulling gently with the precision tweezers.
    • Remove the jawbone connector with the precision tweezers.
    询问修复机器人
    添加评论
  11. HTC Amaze Front Facing Camera Replacement: 步骤 11 中的图像 1,2 HTC Amaze Front Facing Camera Replacement: 步骤 11 中的图像 2,2
    • Carefully pull the motherboard out of its recess.
    询问修复机器人
    添加评论
  12. HTC Amaze Front Facing Camera Replacement, Front Facing Camera: 步骤 12 中的图像 1,2 HTC Amaze Front Facing Camera Replacement, Front Facing Camera: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    • Locate the camera at the top right of the interior side of the motherboard, and remove the tape holding its connector in place. Peel back the tape using the precision tweezers
    • While holding the tape away, gently lift the camera up with the precision tweezers.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Jonah DIngle
于09/22/16注册
286 声望
创作了2篇指南
团队
USF Tampa, Team 16-3, Eyestone Fall 2016 USF Tampa, Team 16-3, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S16G3
2 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 39
总计 447
