跳转到主内容
加入维修社区 - 创建账户
HP w2216h Screen Replacement
你所需要的
    1. HP w2216h Screen Replacement, Screen: 步骤 1 中的图像 1,1
      • 'Make sure you are grounded, the power supply is not connected and you are wearing safety goggles.
      • Use the Philips #000 screwdriver to remove the 4 round12mm screws on the back panel.
      询问修复机器人
      添加评论
    2. HP w2216h Screen Replacement: 步骤 2 中的图像 1,2 HP w2216h Screen Replacement: 步骤 2 中的图像 2,2
      • Using a Philips #000 head remove 2 flat 12 mm screws above stand mounting bracket.
      • Using a PH1 Philips head with the 150 mm flexible extension remove 1 Philips head screw under the stand mounting bracket.
      • Stand will easily pull off.
      询问修复机器人
      添加评论
    3. HP w2216h Screen Replacement: 步骤 3 中的图像 1,3 HP w2216h Screen Replacement: 步骤 3 中的图像 2,3 HP w2216h Screen Replacement: 步骤 3 中的图像 3,3
      • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
      • Turn monitor so that the screen is facing you.
      • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
      • The best places to pry are in the lower left and lower right corners of the black bezel.
      询问修复机器人
      添加评论
    4. HP w2216h Screen Replacement: 步骤 4 中的图像 1,3 HP w2216h Screen Replacement: 步骤 4 中的图像 2,3 HP w2216h Screen Replacement: 步骤 4 中的图像 3,3
      • Be careful of the wires attaching the power button and the control buttons. Show extreme caution to ensure the button is not damaged.
      • Lift the screen assembly from the plastic housing from the corners.
      添加评论
    5. HP w2216h Screen Replacement: 步骤 5 中的图像 1,2 HP w2216h Screen Replacement: 步骤 5 中的图像 2,2
      • Remove the 4 connectors from the left side of the monitor on the back.
      询问修复机器人
      添加评论
    6. HP w2216h Screen Replacement: 步骤 6 中的图像 1,3 HP w2216h Screen Replacement: 步骤 6 中的图像 2,3 HP w2216h Screen Replacement: 步骤 6 中的图像 3,3
      • Lift the gray tape of the top of the monitor to expose the ribbon cable.
      • Remove the ribbon cable by sliding the connector towards the center of the screen assembly.
      • Lift the reflective tape next to the gray tape.
      询问修复机器人
      添加评论
    7. HP w2216h Screen Replacement: 步骤 7 中的图像 1,3 HP w2216h Screen Replacement: 步骤 7 中的图像 2,3 HP w2216h Screen Replacement: 步骤 7 中的图像 3,3
      • Remove the 4 PH1 8mm Philips round screws on the outer edge of the screen's assembly.
      • Lift the screen from the screen assembly.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
UMass Dartmouth, Team 1-1, Miles Spring 2016 UMass Dartmouth, Team 1-1, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G1
4 名成员
创作了12篇指南
3指南评论
I have an HP laptop. How can i fix the screen to my laptop? Will it be the same thing? And how would i know what screen to get for it? Thanks.
Crystal Tejada - 回复 分享
Contact hp corporate they can sell u a replacement screen or a local electronic repair store or even a monitor of equal size should work and assembly is very simular but components are much more sensitive and fragile be careful and best of luck i love comouter repair
Jeremy Cummings - 回复 分享
The lcd panel of my HP 2210i 21.5 inchs monitor has been cracked. No way to find any replacement of this single part. The monitor works, but must go to recicle bin. Very sad.
yajoden - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 46
总计 2,771
