跳转到主内容
加入维修社区 - 创建账户
HP Zbook 15u G2 RAM Replacement
你所需要的
  1. HP Zbook 15u G2 RAM Replacement, RAM/Memory: 步骤 1 中的图像 1,1
    • Flip the laptop on its side and flip the switch at the top so the red side is visible. This will allow you to slide off the back panel as shown.
    询问修复机器人
    添加评论
  2. HP Zbook 15u G2 RAM Replacement: 步骤 2 中的图像 1,2 HP Zbook 15u G2 RAM Replacement: 步骤 2 中的图像 2,2
    • Once the back panel is removed, flip the 2 switches located on the battery so the red is visible.
    • Lift the battery out of the device by pulling up on the tab located between the two switches at the top of the battery.
    询问修复机器人
    添加评论
  3. HP Zbook 15u G2 RAM Replacement: 步骤 3 中的图像 1,1
    • Once you have removed the back panel, you must locate the RAM. The RAM comes in two pieces on the ZBook.
    • Located at the top of the computer, the ram can be located as a part of two pieces held together with a metal clip.
    询问修复机器人
    添加评论
  4. HP Zbook 15u G2 RAM Replacement: 步骤 4 中的图像 1,1
    • Gently pull back the clips and remove the RAM module, which will pop out. Repeat this step for the second RAM Module.
    询问修复机器人
    添加评论
  5. HP Zbook 15u G2 RAM Replacement: 步骤 5 中的图像 1,1
    • Slide the new RAM module back into place and push the module into place. Repeat this process for the second RAM Module.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Nicole Kach
于03/13/23注册
279 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-5, Petersen Spring 2023 UMass Dartmouth, Team 3-5, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S3G5
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 40
总计 433
