跳转到主内容
加入维修社区 - 创建账户
HP ZBook 15 Keyboard Replacement
你所需要的
    1. HP ZBook 15 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 HP ZBook 15 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
      • Flip the laptop over.
      • Slide the lever with the battery symbol beside it firmly until the battery pops out.
      • Remove the battery from the laptop.
      询问修复机器人
      添加评论
    1. HP ZBook 15 Keyboard Replacement, Back Cover: 步骤 2 中的图像 1,1
      • Slide the right lever firmly to the right.
      • Slide the cover towards yourself to remove it.
      询问修复机器人
      添加评论
    1. HP ZBook 15 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
      • Remove the two 16mm screws with a Phillips #0 screwdriver.
      • There are two sets of threads to get past. Once unscrewed from the first thread, lift the screw up until it hits the next set and begin unscrewing again.
      添加评论
    2. HP ZBook 15 Keyboard Replacement: 步骤 4 中的图像 1,3 HP ZBook 15 Keyboard Replacement: 步骤 4 中的图像 2,3 HP ZBook 15 Keyboard Replacement: 步骤 4 中的图像 3,3
      • Do not try to pry the keyboard from the bottom. The keyboard is attached by clips on the left, top, and right side. Metal inserts on the bottom side lock the keyboard in place until they are slid up and out.
      • Be careful not to scratch or chip the computer when prying. If you have a plastic tool that is long enough to gain leverage, use that instead of a metal tool.
      • There are ribbons secured underneath so be careful not to pull the keyboard out too hard, breaking the connections to the ribbons.
      • Flip the laptop over so the keyboard is visible.
      • Insert the spudger under the left side of the keyboard.
      • Carefully raise the side of the keyboard and firmly pull the left corner of the keyboard until it pops up.
      • Run your fingers under the edges of the keyboard along the top edge of the keyboard, from the top left to the top right, to separate it from the remaining clips.
      • Carefully slide the keyboard up toward the screen and out of the case.
      添加评论
    3. HP ZBook 15 Keyboard Replacement: 步骤 5 中的图像 1,3 HP ZBook 15 Keyboard Replacement: 步骤 5 中的图像 2,3 HP ZBook 15 Keyboard Replacement: 步骤 5 中的图像 3,3
      • Gently lift the two tabs on either side of the black ribbon with a spudger until the ribbon comes loose.
      • Disconnect the black ribbon by pulling the blue tab hanging off of it.
      • Repeat with the white ribbon.
      添加评论
结论
取消:我没有完成这个指南。
34等其他人完成本指南。
Grant Terris
于01/30/15注册
2,888 声望
创作了12篇指南
团队
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 的会员
CPSU-AMIDO-W15S8G43
4 名成员
创作了95篇指南
13指南评论
I found that if you remove the optical drive, you have access to push the keyboard form the back to disengage the side with the number pad.
bryanholder81 - 回复 分享
I agree with Bryan...much easier to start that way. Pushing from the back will disengage the top right corner (seen from the user position)
advrider - 回复 分享
In addition to the comments about pushing the keyboard out after removing the optical drive (which is actually the documented way of removing the keyboard) I'd add that the bit about "There are two sets of threads to get past. Once unscrewed from the first thread, lift the screw up until it hits the next set and begin unscrewing again." is incorrect. The screws are deliberately designed to be self retaining. You only need to unscrew it until the screw turns freely (i.e. not fully).
Dominic Cioccarelli - 回复 分享
please, will they have the part number of this keyboard ?, it hurt me and I saw the steps that are followed to extract it, and replace it, but I can not find the part number of the keyboard replacement, if someone could have it tell me which is please?
cesar rios - 回复 分享
Go to partsurfer.hp.com with the p/n of the machine and you'll get the exact part number of the keyboard you need
Johan Rios - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 145
总计 70,680
