跳转到主内容
加入维修社区 - 创建账户
HP Stream 13-c002dx Wireless Card Replacement
你所需要的
    1. HP Stream 13-c002dx Wireless Card  Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Stream 13-c002dx Wireless Card  Replacement, Keyboard: 步骤 1 中的图像 2,2
      • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
      • Flip the laptop over so the bottom is facing up.
      • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
      • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
      • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
      询问修复机器人
      添加评论
    2. HP Stream 13-c002dx Wireless Card  Replacement: 步骤 2 中的图像 1,3 HP Stream 13-c002dx Wireless Card  Replacement: 步骤 2 中的图像 2,3 HP Stream 13-c002dx Wireless Card  Replacement: 步骤 2 中的图像 3,3
      • Flip the laptop back over so it's right side up and open the screen.
      • Using a spudger, separate the keyboard surface from the bottom of the laptop.
      • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
      • Remove the keyboard assembly.
      询问修复机器人
      添加评论
    1. HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: 步骤 3 中的图像 1,3 HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: 步骤 3 中的图像 2,3 HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: 步骤 3 中的图像 3,3
      • Inside the laptop you will notice the wireless card located in the upper middle. This will be what you are replacing.
      • Attached to the Wi-Fi card is a black wire that must be removed. Using your hand, lift gently on the wire as close as you can to where it connects to the Wi-Fi card.
      • Once the wire is removed, set it aside so it does not get damaged.
      询问修复机器人
      添加评论
    2. HP Stream 13-c002dx Wireless Card  Replacement: 步骤 4 中的图像 1,3 HP Stream 13-c002dx Wireless Card  Replacement: 步骤 4 中的图像 2,3 HP Stream 13-c002dx Wireless Card  Replacement: 步骤 4 中的图像 3,3
      • Remove the screw holding the wireless card in place.
      • With the screw removed, gently pull back the Wi-Fi card and then lift it out of the laptop. You are now ready to insert the new wireless card.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 34
总计 1,806
