跳转到主内容
加入维修社区 - 创建账户
HP Stream 11-d020nr Webcam Replacement
你所需要的
  1. HP Stream 11-d020nr Webcam Replacement, Lower Case: 步骤 1 中的图像 1,3 HP Stream 11-d020nr Webcam Replacement, Lower Case: 步骤 1 中的图像 2,3 HP Stream 11-d020nr Webcam Replacement, Lower Case: 步骤 1 中的图像 3,3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
    询问修复机器人
    添加评论
  2. HP Stream 11-d020nr Webcam Replacement: 步骤 2 中的图像 1,2 HP Stream 11-d020nr Webcam Replacement: 步骤 2 中的图像 2,2
    • Remove the eleven 5.6 mm Phillips #00 screws.
    询问修复机器人
    添加评论
  3. HP Stream 11-d020nr Webcam Replacement: 步骤 3 中的图像 1,3 HP Stream 11-d020nr Webcam Replacement: 步骤 3 中的图像 2,3 HP Stream 11-d020nr Webcam Replacement: 步骤 3 中的图像 3,3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
    添加评论
  4. HP Stream 11-d020nr Webcam Replacement: 步骤 4 中的图像 1,3 HP Stream 11-d020nr Webcam Replacement: 步骤 4 中的图像 2,3 HP Stream 11-d020nr Webcam Replacement: 步骤 4 中的图像 3,3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
    添加评论
  5. HP Stream 11-d020nr Webcam Replacement, Keyboard: 步骤 5 中的图像 1,2 HP Stream 11-d020nr Webcam Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Tilt the top of the keyboard plate up until you separate it from the base.
    • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
    询问修复机器人
    添加评论
  6. HP Stream 11-d020nr Webcam Replacement: 步骤 6 中的图像 1,3 HP Stream 11-d020nr Webcam Replacement: 步骤 6 中的图像 2,3 HP Stream 11-d020nr Webcam Replacement: 步骤 6 中的图像 3,3
    • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
    • After disengaging the connectors, gently unplug both ribbon cables.
    询问修复机器人
    添加评论
  7. HP Stream 11-d020nr Webcam Replacement, Lid: 步骤 7 中的图像 1,3 HP Stream 11-d020nr Webcam Replacement, Lid: 步骤 7 中的图像 2,3 HP Stream 11-d020nr Webcam Replacement, Lid: 步骤 7 中的图像 3,3
    • Lift the black flap on the display cable ZIF connector.
    • After lifting the flap, gently pull the display cable from its socket.
    • Disconnect the wireless antenna from the wireless card.
    • Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
    询问修复机器人
    添加评论
  8. HP Stream 11-d020nr Webcam Replacement: 步骤 8 中的图像 1,3 HP Stream 11-d020nr Webcam Replacement: 步骤 8 中的图像 2,3 HP Stream 11-d020nr Webcam Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to remove the screw covers from the lid.
    • Remove the two 2.2 mm Phillips #000 screws.
    • Use a plastic opening tool to disengage the front part of the lid.
    询问修复机器人
    添加评论
  9. HP Stream 11-d020nr Webcam Replacement, Webcam: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tweezers to remove the wire connected to the webcam.
    询问修复机器人
    添加评论
  10. HP Stream 11-d020nr Webcam Replacement: 步骤 10 中的图像 1,1
    • Use the tweezers to pull the webcam off of the frame.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Spenser Mason
于02/04/16注册
1,781 声望
创作了6篇指南
团队
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016 的会员
USFT-WOLLERT-S16S3G5
5 名成员
创作了19篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 709
