跳转到主内容
加入维修社区 - 创建账户
HP Stream 11-d020nr Trackpad Replacement
你所需要的
  1. HP Stream 11-d020nr Trackpad Replacement, Lower Case: 步骤 1 中的图像 1,3 HP Stream 11-d020nr Trackpad Replacement, Lower Case: 步骤 1 中的图像 2,3 HP Stream 11-d020nr Trackpad Replacement, Lower Case: 步骤 1 中的图像 3,3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
    询问修复机器人
    添加评论
  2. HP Stream 11-d020nr Trackpad Replacement: 步骤 2 中的图像 1,2 HP Stream 11-d020nr Trackpad Replacement: 步骤 2 中的图像 2,2
    • Remove the eleven 5.6 mm Phillips #00 screws.
    询问修复机器人
    添加评论
  3. HP Stream 11-d020nr Trackpad Replacement: 步骤 3 中的图像 1,3 HP Stream 11-d020nr Trackpad Replacement: 步骤 3 中的图像 2,3 HP Stream 11-d020nr Trackpad Replacement: 步骤 3 中的图像 3,3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
    询问修复机器人
    添加评论
  4. HP Stream 11-d020nr Trackpad Replacement: 步骤 4 中的图像 1,3 HP Stream 11-d020nr Trackpad Replacement: 步骤 4 中的图像 2,3 HP Stream 11-d020nr Trackpad Replacement: 步骤 4 中的图像 3,3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
    询问修复机器人
    添加评论
  5. HP Stream 11-d020nr Trackpad Replacement, Trackpad: 步骤 5 中的图像 1,2 HP Stream 11-d020nr Trackpad Replacement, Trackpad: 步骤 5 中的图像 2,2
    • On the back of the plastic keyboard cover, remove the two 2 mm Phillips #000 screws.
    询问修复机器人
    添加评论
  6. HP Stream 11-d020nr Trackpad Replacement: 步骤 6 中的图像 1,1
    • Lift up the plastic cover to release the ClickPad.
    询问修复机器人
    添加评论
结论
To reassemble your computer, follow these instructions in reverse order.
取消:我没有完成这个指南。
4等其他人完成本指南。
Spenser Mason
于02/04/16注册
1,781 声望
创作了6篇指南
团队
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016 的会员
USFT-WOLLERT-S16S3G5
5 名成员
创作了19篇指南
2指南评论
windows 8.1 y windows 10 no detectan el clickpad ni en el administrador de dispositivos, como si no existiera pero al arrancar de un cdlive de ubuntu lo reconoce perfectamente. alguien sabra que podria ser?
Oscar - 回复 分享
Can you give the Product number of the part?
NÖME Technologys and Designs - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 40
总计 1,862
