跳转到主内容
加入维修社区 - 创建账户
HP Stream 11-d020nr Battery Replacement
你所需要的
    1. HP Stream 11-d020nr Battery Replacement, Lower Case: 步骤 1 中的图像 1,3 HP Stream 11-d020nr Battery Replacement, Lower Case: 步骤 1 中的图像 2,3 HP Stream 11-d020nr Battery Replacement, Lower Case: 步骤 1 中的图像 3,3
      • Before disassembly, unplug and power off the Stream 11.
      • Pry off the two elliptical rubber inserts (one in each corner).
      • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
      询问修复机器人
      添加评论
    2. HP Stream 11-d020nr Battery Replacement: 步骤 2 中的图像 1,2 HP Stream 11-d020nr Battery Replacement: 步骤 2 中的图像 2,2
      • Remove the eleven 5.6 mm Phillips #00 screws.
      询问修复机器人
      添加评论
    3. HP Stream 11-d020nr Battery Replacement: 步骤 3 中的图像 1,3 HP Stream 11-d020nr Battery Replacement: 步骤 3 中的图像 2,3 HP Stream 11-d020nr Battery Replacement: 步骤 3 中的图像 3,3
      • Turn the computer upright and lift the screen.
      • Carefully use a spudger to pry the plastic keyboard cover from the base.
      • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
      • Work the spudger around the cover to release the clips attaching the cover to the base.
      • Be patient when removing the cover, as there are many clips and it may take some time.
      添加评论
    4. HP Stream 11-d020nr Battery Replacement: 步骤 4 中的图像 1,3 HP Stream 11-d020nr Battery Replacement: 步骤 4 中的图像 2,3 HP Stream 11-d020nr Battery Replacement: 步骤 4 中的图像 3,3
      • Disconnect the cable connecting the ClickPad to the base.
      • Remove the plastic keyboard cover.
      • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
      添加评论
    1. HP Stream 11-d020nr Battery Replacement, Keyboard: 步骤 5 中的图像 1,2 HP Stream 11-d020nr Battery Replacement, Keyboard: 步骤 5 中的图像 2,2
      • Tilt the top of the keyboard plate up until you separate it from the base.
      • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
      询问修复机器人
      添加评论
    2. HP Stream 11-d020nr Battery Replacement: 步骤 6 中的图像 1,3 HP Stream 11-d020nr Battery Replacement: 步骤 6 中的图像 2,3 HP Stream 11-d020nr Battery Replacement: 步骤 6 中的图像 3,3
      • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
      • After disengaging the connectors, gently unplug both ribbon cables.
      询问修复机器人
      添加评论
    1. HP Stream 11-d020nr Battery Replacement, Battery: 步骤 7 中的图像 1,2 HP Stream 11-d020nr Battery Replacement, Battery: 步骤 7 中的图像 2,2
      • Remove any tape covering the battery connector.
      • Disconnect the battery cable from its socket on the motherboard.
      询问修复机器人
      添加评论
    2. HP Stream 11-d020nr Battery Replacement: 步骤 8 中的图像 1,3 HP Stream 11-d020nr Battery Replacement: 步骤 8 中的图像 2,3 HP Stream 11-d020nr Battery Replacement: 步骤 8 中的图像 3,3
      • Unscrew the four 3.3mm Phillips #000 screws.
      • Lift the battery out gently.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
22等其他人完成本指南。
Spenser Mason
于02/04/16注册
1,781 声望
创作了6篇指南
团队
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016 的会员
USFT-WOLLERT-S16S3G5
5 名成员
创作了52篇指南
4指南评论
Thank you for the guide. For us it was enough to unplug the battery and then plug it back in. The problem we encountered was that the capslock would blink on startup for the HP Stream 11.
ruudvanleeuwen - 回复 分享
Would this fix work for a HP notebook Model 11-N012NA. ?
Denis Mahony - 回复 分享
Would this work for my House notebook PC 11-d011wm?
If I put the charger the thing will Will just start blinking
Abdul Rahman - 回复 分享
Worked fine but I didn’t need to unplug the ribbon cables. Merely had to lean the keyboard against the screen and remove the battery.
Would advise taking a picture of the ribbon cables to make sure they are in far enough on completion.
des.lyde - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 69
总计 50,075
