跳转到主内容
加入维修社区 - 创建账户
HP Stream 11-d010nr Webcam Replacement
你所需要的
  1. HP Stream 11-d010nr Webcam Replacement, Pry out the inserts: 步骤 1 中的图像 1,2 HP Stream 11-d010nr Webcam Replacement, Pry out the inserts: 步骤 1 中的图像 2,2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
    询问修复机器人
    添加评论
  2. HP Stream 11-d010nr Webcam Replacement, Unscrew the back cover: 步骤 2 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
    询问修复机器人
    添加评论
  3. HP Stream 11-d010nr Webcam Replacement, Pry the keyboard casing up: 步骤 3 中的图像 1,2 HP Stream 11-d010nr Webcam Replacement, Pry the keyboard casing up: 步骤 3 中的图像 2,2
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
    询问修复机器人
    添加评论
  4. HP Stream 11-d010nr Webcam Replacement, Identify the connectors: 步骤 4 中的图像 1,1
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
    询问修复机器人
    添加评论
  5. HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: 步骤 5 中的图像 1,3 HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: 步骤 5 中的图像 2,3 HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: 步骤 5 中的图像 3,3
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
    询问修复机器人
    添加评论
  6. HP Stream 11-d010nr Webcam Replacement, Lift the keyboard out: 步骤 6 中的图像 1,1
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
    询问修复机器人
    添加评论
  7. HP Stream 11-d010nr Webcam Replacement, Battery: 步骤 7 中的图像 1,1
    • Remove any tape holding the battery connector in place.
    • Using your fingers, carefully unplug the battery.
    询问修复机器人
    添加评论
  8. HP Stream 11-d010nr Webcam Replacement: 步骤 8 中的图像 1,2 HP Stream 11-d010nr Webcam Replacement: 步骤 8 中的图像 2,2
    • Remove the four 3mm #000 Phillips screws holding the battery in place.
    • Carefully lift the battery out of the laptop.
    询问修复机器人
    添加评论
  9. HP Stream 11-d010nr Webcam Replacement, Wifi Chip: 步骤 9 中的图像 1,2 HP Stream 11-d010nr Webcam Replacement, Wifi Chip: 步骤 9 中的图像 2,2
    • Unplug the black wire attached to the wireless chip.
    询问修复机器人
    添加评论
  10. HP Stream 11-d010nr Webcam Replacement: 步骤 10 中的图像 1,2 HP Stream 11-d010nr Webcam Replacement: 步骤 10 中的图像 2,2
    • Remove the one 3mm Phillips #000 screw holding the wireless chip in place.
    • Lift the wireless chip up and out.
    询问修复机器人
    添加评论
  11. HP Stream 11-d010nr Webcam Replacement, Webcam: 步骤 11 中的图像 1,3 HP Stream 11-d010nr Webcam Replacement, Webcam: 步骤 11 中的图像 2,3 HP Stream 11-d010nr Webcam Replacement, Webcam: 步骤 11 中的图像 3,3
    • Flip up the flap and unplug the display cord from the motherboard.
    询问修复机器人
    添加评论
  12. HP Stream 11-d010nr Webcam Replacement: 步骤 12 中的图像 1,2 HP Stream 11-d010nr Webcam Replacement: 步骤 12 中的图像 2,2
    • Using a JIS #1 screwdriver, remove the four 2.2 mm screws holding monitor to body.
    询问修复机器人
    添加评论
  13. HP Stream 11-d010nr Webcam Replacement: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to remove the screw covers from the lid.
    • Unscrew the two 2.2 mm #000 Phillips screws.
    询问修复机器人
    添加评论
  14. HP Stream 11-d010nr Webcam Replacement: 步骤 14 中的图像 1,1
    • Open the upper lid with the iFixit opening tool.
    询问修复机器人
    添加评论
  15. HP Stream 11-d010nr Webcam Replacement: 步骤 15 中的图像 1,2 HP Stream 11-d010nr Webcam Replacement: 步骤 15 中的图像 2,2
    • Disconnect the webcam cord using tweezers.
    • Remove the webcam using tweezers.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team S1-G3, White Winter 2019 Cal Poly, Team S1-G3, White Winter 2019 的会员
CPSU-WHITE-W19S1G3
4 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 38
总计 708
