跳转到主内容
加入维修社区 - 创建账户
HP ProBook 650 G4 Keyboard Replacement
你所需要的
  1. HP ProBook 650 G4 Keyboard Replacement, Remove Back Plate: 步骤 1 中的图像 1,1
    • Loosen the 8 Philips screws circled in red in the photo. These screws are captive and should not come out fully.
    • Use pry tool starting at one of the hinges to release the clips all around the back plate
    • Remove plate and set aside.
    询问修复机器人
    添加评论
  2. HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: 步骤 2 中的图像 1,3 HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: 步骤 2 中的图像 2,3 HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: 步骤 2 中的图像 3,3
    • Unscrew the 3 Philips screws by the keyboard icons. (Circled in red)
    • The screws are captive and should not be removed fully.
    • Open the laptop screen
    • Use keyboard removal tool to push out the keyboard (circled in green)
    • anything that fits in the hole could be used if tool not available.
    询问修复机器人
    添加评论
  3. HP ProBook 650 G4 Keyboard Replacement, Releasing keyboard: 步骤 3 中的图像 1,2 HP ProBook 650 G4 Keyboard Replacement, Releasing keyboard: 步骤 3 中的图像 2,2
    • Work around the keyboard releasing the clips.
    • Clips are only located on the top, left, and right of the keyboard.
    • flip the keyboard towards the mouse pad taking care not to damage the ribbon cables.
    询问修复机器人
    添加评论
  4. HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: 步骤 4 中的图像 1,3 HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: 步骤 4 中的图像 2,3 HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: 步骤 4 中的图像 3,3
    • with a plastic spudger tool flip up the black clips to release the ribbon cables
    • Gently pull out the cables, there should be no resistance if the clips were opened properly.
    • There may be some adhesive connecting the cable to the keyboard (green arrow).
    询问修复机器人
    添加评论
  5. HP ProBook 650 G4 Keyboard Replacement, Install New Ribbon Cables: 步骤 5 中的图像 1,2 HP ProBook 650 G4 Keyboard Replacement, Install New Ribbon Cables: 步骤 5 中的图像 2,2
    • Gently fold the new ribbon cables at the 15B line
    • Gently push in the ribbon cables and press down the black clips.
    • Make sure that the cables are pushed in far enough. They have a line marking how far they should be inserted.
    • Slide in the bottom clips of the keyboard and flip towards the screen
    • Push the keyboard all around until all of the clips click into place.
    询问修复机器人
    添加评论
  6. HP ProBook 650 G4 Keyboard Replacement, Reassemble Laptop: 步骤 6 中的图像 1,2 HP ProBook 650 G4 Keyboard Replacement, Reassemble Laptop: 步骤 6 中的图像 2,2
    • Screw in the 3 keyboard screws
    • Push the back plate on and screw in the 8 screws
    • Go around the back plate making sure that it is clipped in all around.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
1指南评论
Datasheet motherboard
No power in d
evice
Mahmoud Ahmed - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 78
总计 4,503
