跳转到主内容
加入维修社区 - 创建账户
HP ProBook 645 Keyboard Replacement
你所需要的
    1. HP ProBook 645 Keyboard Replacement, Remove 2 screws: 步骤 1 中的图像 1,1
      • Remove the two screws at the two indicated locations with the phillips head screw driver.
      询问修复机器人
      添加评论
    2. HP ProBook 645 Keyboard Replacement, Flip unit over and open lid.: 步骤 2 中的图像 1,1
      • Take a spudger tool and pry the keyboard down toward the mouse pad and up toward you. After you raise the keyboard there are tabs at the bottom. Pull the keyboard away from you, and it will dislodge.
      询问修复机器人
      添加评论
    3. HP ProBook 645 Keyboard Replacement, Ribbon Removal: 步骤 3 中的图像 1,1
      • 1. Remove ribbon by flipping the black tab up and gently pulling on the ribbon.
      • 2. This ribbon has no tab, gently pull on until it comes loose. To reinsert. Line it up carefully as not to damage the ribbon, and push gently.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Doug
于04/02/15注册
191 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 42
总计 4,957
