简介
Use this guide to replace a faulty or damaged SSD in the HP ProBook 640 G5 laptop. If your laptop is not booting, showing "No boot device found", experiencing slow performance, or failing to load the operating system, the SSD may be the cause. This guide will show you how to safely remove the bottom cover, locate the SSD, and remove the existing drive to install a new one. Before starting, power off the laptop completely and disconnect all power sources.
你所需要的
Shut down the HP ProBook 640 G5 completely.
Disconnect the power adapter and all connected peripherals.
Press and hold the power button for 5 seconds to discharge remaining electricity.
