跳转到主内容
加入维修社区 - 创建账户
HP ProBook 640 G5 RAM Replacement
你所需要的
    1. HP ProBook 640 G5 RAM Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Always make sure the HP ProBook 640 G5 is completely powered off and unplugged before beginning this repair. Attempting to open the laptop while it has power may cause electrical damage or personal injury.
      • Shut down the HP ProBook 640 G5 completely.
      • Disconnect the power adapter and all connected peripherals.
      • Press and hold the power button for 5 seconds to discharge remaining electricity.
      询问修复机器人
      添加评论
    2. HP ProBook 640 G5 RAM Replacement: 步骤 2 中的图像 1,1
      • Flip the laptop over so the bottom is facing up.
      • Loosen eight silver 6mm screws using a Phillips #0 screwdriver.
      • These screws are captive, so they will loosen but remain attached to the cover.
      • Remove two black 6mm screws using a TR7 Torx screwdriver.
      • Insert a plastic opening tool into the seam and gently pry around the edges.
      • Lift the bottom cover away from the laptop.
      询问修复机器人
      添加评论
    1. HP ProBook 640 G5 RAM Replacement, RAM: 步骤 3 中的图像 1,1
      • When replacing RAM, avoid touching the gold contacts and black chips. Handle the stick only by its outer edges or plastic/metal shielding. Touching the chips or gold contacts can introduce static electricity or oil from your fingers, potentially causing damage or poor connectivity.
      • Locate the RAM you intend on replacing/upgrading.
      • Some laptops may come with two sticks of RAM; the one we are working on is equipped with only one.
      询问修复机器人
      添加评论
    2. HP ProBook 640 G5 RAM Replacement: 步骤 4 中的图像 1,1
      • Gently push outward on the two retaining clips on each side of the module.
      • The RAM stick will pop up at a 30-degree angle.
      • Hold the RAM module by the edges (avoid touching the gold contacts).
      • Slide it out of the slot at the same angle it popped up.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 30
总计 169
