跳转到主内容
加入维修社区 - 创建账户
HP ProBook 640 G5 Battery Replacement
你所需要的
    1. HP ProBook 640 G5 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Always make sure the HP ProBook 640 G5 is completely powered off and unplugged before beginning this repair. Attempting to open the laptop while it has power may cause electrical damage or personal injury.
      • Shut down the HP ProBook 640 G5 completely.
      • Disconnect the power adapter and all connected peripherals.
      • Press and hold the power button for 5 seconds to discharge remaining electricity.
      询问修复机器人
      添加评论
    2. HP ProBook 640 G5 Battery Replacement: 步骤 2 中的图像 1,1
      • Flip the laptop over so the bottom is facing up.
      • Loosen eight silver 6mm screws using a Phillips #0 screwdriver.
      • These screws are captive, so they will loosen but remain attached to the cover.
      • Remove two black 6mm screws using a TR7 Torx screwdriver.
      • Insert a plastic opening tool into the seam and gently pry around the edges.
      • Lift the bottom cover away from the laptop.
      询问修复机器人
      添加评论
    1. HP ProBook 640 G5 Battery Replacement, Battery: 步骤 3 中的图像 1,3 HP ProBook 640 G5 Battery Replacement, Battery: 步骤 3 中的图像 2,3 HP ProBook 640 G5 Battery Replacement, Battery: 步骤 3 中的图像 3,3
      • Remove six 6mm and two 2mm screws using a Phillips #0 screwdriver.
      • The screws on the battery can be hard to remove as they need to be unscrewed, stood up, then unscrewed fully. You can use the tweezers to pull up the screw in place. You'll know it's in the proper place when you go to unscrew it and it comes out smoothly.
      询问修复机器人
      添加评论
    2. HP ProBook 640 G5 Battery Replacement: 步骤 4 中的图像 1,2 HP ProBook 640 G5 Battery Replacement: 步骤 4 中的图像 2,2
      • Lift the battery near the lower end and pull it out of the slot on the top.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jack Cowan
于02/23/26注册
85 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 49
总计 145
