跳转到主内容
加入维修社区 - 创建账户
HP ProBook 640 G1 Midframe Replacement
你所需要的
    1. HP ProBook 640 G1 Midframe Replacement, Battery: 步骤 1 中的图像 1,1
      • Turn the laptop upside down to show the battery lock slider.
      • It is a black slider near the top, with a battery logo to the left and a lock sign to the right.
      询问修复机器人
      添加评论
    2. HP ProBook 640 G1 Midframe Replacement: 步骤 2 中的图像 1,1
      • Slide the battery slider all the way to the left, towards the battery symbol.
      • You may also need to slide the other slider to the right of the battery slider, as shown in the picture.
      询问修复机器人
      添加评论
    3. HP ProBook 640 G1 Midframe Replacement: 步骤 3 中的图像 1,1
      • Remove the battery by sliding it away from the laptop while holding the battery locker.
      • The battery should slide out with ease.
      询问修复机器人
      添加评论
    1. HP ProBook 640 G1 Midframe Replacement, Back Panel: 步骤 4 中的图像 1,2 HP ProBook 640 G1 Midframe Replacement, Back Panel: 步骤 4 中的图像 2,2
      • Slide down and pull up on the cover to remove it.
      询问修复机器人
      添加评论
    1. HP ProBook 640 G1 Midframe Replacement, Midframe: 步骤 5 中的图像 1,3 HP ProBook 640 G1 Midframe Replacement, Midframe: 步骤 5 中的图像 2,3 HP ProBook 640 G1 Midframe Replacement, Midframe: 步骤 5 中的图像 3,3
      • Remove the eight rubber screw plugs from the bottom and the two rubber screw plugs from the sides of the laptop using a paperclip.
      • Remove the fourteen 6 mm screws from the bottom of the laptop and the two 6 mm screws from the sides using a T8 Torx screwdriver.
      • Remove the six 4 mm screws that secure the midframe using a T8 Torx screwdriver.
      • Some of the screws are held in place by springs and cannot be fully removed, but can still be loosened.
      询问修复机器人
      添加评论
    2. HP ProBook 640 G1 Midframe Replacement: 步骤 6 中的图像 1,2 HP ProBook 640 G1 Midframe Replacement: 步骤 6 中的图像 2,2
      • Remove the disk drive by gently pulling it out.
      • Remove the two 3 mm screws using a Phillips #1 screwdriver.
      • Only one screw is visible in the photo the second screw is located directly above it.
      询问修复机器人
      添加评论
    3. HP ProBook 640 G1 Midframe Replacement: 步骤 7 中的图像 1,2 HP ProBook 640 G1 Midframe Replacement: 步骤 7 中的图像 2,2
      • Gently pull up on the midframe, gripping it from the inside.
      • This may take a small amount of force. If it feels stuck, check for missed screws. Go back to the previous steps and make sure you have removed all necessary screws.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 4-2, Biswokarma Fall 2025 UMass Dartmouth, Team 4-2, Biswokarma Fall 2025 的会员
UMASSD-BISWOKARMA-F25S4G2
5 名成员
创作了48篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 48
总计 317
