跳转到主内容
加入维修社区 - 创建账户
HP ProBook 450 G4 Keyboard Replacement
你所需要的
    1. HP ProBook 450 G4 Keyboard Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP ProBook 450 G4 Keyboard Replacement, Hard Drive: 步骤 1 中的图像 2,2
      • Power your laptop off.
      • Flip the laptop over.
      • Orient the laptop so the two vents on the bottom face upward and are further away from you.
      询问修复机器人
      添加评论
    2. HP ProBook 450 G4 Keyboard Replacement: 步骤 2 中的图像 1,3 HP ProBook 450 G4 Keyboard Replacement: 步骤 2 中的图像 2,3 HP ProBook 450 G4 Keyboard Replacement: 步骤 2 中的图像 3,3
      • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
      • Use the spudger to separate the vent panel from the laptop.
      • Slide the vent panel off the backside of the laptop.
      询问修复机器人
      添加评论
    3. HP ProBook 450 G4 Keyboard Replacement: 步骤 3 中的图像 1,2 HP ProBook 450 G4 Keyboard Replacement: 步骤 3 中的图像 2,2
      • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
      询问修复机器人
      添加评论
    4. HP ProBook 450 G4 Keyboard Replacement: 步骤 4 中的图像 1,2 HP ProBook 450 G4 Keyboard Replacement: 步骤 4 中的图像 2,2
      • Use the spudger to lift the left side of the hard drive up.
      • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
      询问修复机器人
      添加评论
    1. HP ProBook 450 G4 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,3 HP ProBook 450 G4 Keyboard Replacement, Keyboard: 步骤 5 中的图像 2,3 HP ProBook 450 G4 Keyboard Replacement, Keyboard: 步骤 5 中的图像 3,3
      • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
      • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
      询问修复机器人
      添加评论
    2. HP ProBook 450 G4 Keyboard Replacement: 步骤 6 中的图像 1,3 HP ProBook 450 G4 Keyboard Replacement: 步骤 6 中的图像 2,3 HP ProBook 450 G4 Keyboard Replacement: 步骤 6 中的图像 3,3
      • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
      • Apply pressure to the black tabs until they release and pop out.
      添加评论
    3. HP ProBook 450 G4 Keyboard Replacement: 步骤 7 中的图像 1,3 HP ProBook 450 G4 Keyboard Replacement: 步骤 7 中的图像 2,3 HP ProBook 450 G4 Keyboard Replacement: 步骤 7 中的图像 3,3
      • Orient the laptop so the keyboard is facing upwards and towards you.
      • Insert the spudger in between the edge of the keyboard and the computer frame.
      • Slide the spudger around the edge of the keyboard until the keyboard is loose.
      • Gently pull the keyboard away from the body of the laptop.
      • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
      询问修复机器人
      添加评论
    4. HP ProBook 450 G4 Keyboard Replacement: 步骤 8 中的图像 1,2 HP ProBook 450 G4 Keyboard Replacement: 步骤 8 中的图像 2,2
      • Use a spudger to gently lift up the black locking bar on the keyboard connector.
      • Slide the keyboard ribbon out of the connector.
      • Remove the keyboard.
      • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Sebastian Dow
于01/23/20注册
1,127 声望
创作了6篇指南
团队
Cal Poly, Team S1-G3, White Winter 2020 Cal Poly, Team S1-G3, White Winter 2020 的会员
CPSU-WHITE-W20S1G3
4 名成员
创作了54篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 86
总计 9,934
