跳转到主内容
加入维修社区 - 创建账户
HP ProBook 4320t Processor Heat Sink Replacement Guide
你所需要的
  1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: 步骤 1 中的图像 1,2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: 步骤 1 中的图像 2,2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    询问修复机器人
    添加评论
  2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: 步骤 2 中的图像 1,2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: 步骤 2 中的图像 2,2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    询问修复机器人
    添加评论
  3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Flip: 步骤 3 中的图像 1,1
    • Flip laptop over and open it.
    询问修复机器人
    添加评论
  4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Push N Lift: 步骤 4 中的图像 1,1
    • Slightly push up while lifting up on the power button panel to release the panel.
    询问修复机器人
    添加评论
  5. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrewing: 步骤 5 中的图像 1,1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    询问修复机器人
    添加评论
  6. HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: 步骤 6 中的图像 1,2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: 步骤 6 中的图像 2,2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
    询问修复机器人
    添加评论
  7. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: 步骤 7 中的图像 1,1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    询问修复机器人
    添加评论
  8. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrew: 步骤 8 中的图像 1,1
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
    询问修复机器人
    添加评论
  9. HP ProBook 4320t Processor Heat Sink Replacement Guide, Slide the Panel Off: 步骤 9 中的图像 1,1
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
    询问修复机器人
    添加评论
  10. HP ProBook 4320t Processor Heat Sink Replacement Guide, Lift up Carefully: 步骤 10 中的图像 1,1
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
    询问修复机器人
    添加评论
  11. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: 步骤 11 中的图像 1,1
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
    询问修复机器人
    添加评论
  12. HP ProBook 4320t Processor Heat Sink Replacement Guide, Computer Fan: 步骤 12 中的图像 1,1
    • Locate silver holding panel on the left side of the computer.
    询问修复机器人
    添加评论
  13. HP ProBook 4320t Processor Heat Sink Replacement Guide: 步骤 13 中的图像 1,1
    • Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
    • Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
    询问修复机器人
    添加评论
  14. HP ProBook 4320t Processor Heat Sink Replacement Guide: 步骤 14 中的图像 1,1
    • Remove holding panel and put aside.
    询问修复机器人
    添加评论
  15. HP ProBook 4320t Processor Heat Sink Replacement Guide: 步骤 15 中的图像 1,1
    • Disconnect the red, black, and blue ribbon cable connector using the black spudger.
    询问修复机器人
    添加评论
  16. HP ProBook 4320t Processor Heat Sink Replacement Guide: 步骤 16 中的图像 1,1
    • Unscrew the one (2.0 mm Phillips) screw holding in the fan.
    询问修复机器人
    添加评论
  17. HP ProBook 4320t Processor Heat Sink Replacement Guide: 步骤 17 中的图像 1,1
    • Lift fan up carefully and replace.
    询问修复机器人
    添加评论
  18. HP ProBook 4320t Processor Heat Sink Replacement Guide, Processor Heat Sink: 步骤 18 中的图像 1,1
    • Unscrew the four (2.5 mm Phillips) screws holding the processor heat sink in (located near the center of the laptop)
    询问修复机器人
    添加评论
  19. HP ProBook 4320t Processor Heat Sink Replacement Guide: 步骤 19 中的图像 1,1
    • Lift slightly on the main component of the heat sink and slowly pull in towards the center (to your right) to free the heat sink.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Eric Markham
于08/29/14注册
227 声望
创作了4篇指南
团队
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G5
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 27
总计 1,418
