跳转到主内容
加入维修社区 - 创建账户
HP Pavilion zv5000 Keyboard Replacement
你所需要的
    1. HP Pavilion zv5000 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
      • Make sure that your device is properly shut down and unplugged from any outlet.
      • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
      询问修复机器人
      添加评论
    2. HP Pavilion zv5000 Keyboard Replacement: 步骤 2 中的图像 1,2 HP Pavilion zv5000 Keyboard Replacement: 步骤 2 中的图像 2,2
      • Press and slide up the battery release tab with your thumb until the battery pops out of place.
      询问修复机器人
      添加评论
    3. HP Pavilion zv5000 Keyboard Replacement: 步骤 3 中的图像 1,2 HP Pavilion zv5000 Keyboard Replacement: 步骤 3 中的图像 2,2
      • Using two fingers, pry the rest of the battery out of the socket.
      询问修复机器人
      添加评论
    1. HP Pavilion zv5000 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 HP Pavilion zv5000 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
      • Using a Phillips #0 screwdriver, unscrew all four Phillips PM 2.5X13.0mm screws and place in a secure area until the end of the project.
      询问修复机器人
      添加评论
    2. HP Pavilion zv5000 Keyboard Replacement: 步骤 5 中的图像 1,1
      • Flip laptop back over and open as far as it can go.
      询问修复机器人
      添加评论
    3. HP Pavilion zv5000 Keyboard Replacement: 步骤 6 中的图像 1,1
      • Use the flat edge of the plastic spudger inserted under the bottom of the strip cover and pry upwards to un-clip the cover, starting at the right and moving to the left.
      • If the plastic spudger is not doing the trick, try using the metal spudger careful to not pop any keys out.
      询问修复机器人
      添加评论
    4. HP Pavilion zv5000 Keyboard Replacement: 步骤 7 中的图像 1,2 HP Pavilion zv5000 Keyboard Replacement: 步骤 7 中的图像 2,2
      • Use hands to completely lift off the strip cover and remove.
      询问修复机器人
      添加评论
    5. HP Pavilion zv5000 Keyboard Replacement: 步骤 8 中的图像 1,1
      • Use the Phillips #0 screwdriver again, unscrew all four Phillips PM 2.5X13.0mm screws from the top of the keyboard and set aside.
      询问修复机器人
      添加评论
    6. HP Pavilion zv5000 Keyboard Replacement: 步骤 9 中的图像 1,2 HP Pavilion zv5000 Keyboard Replacement: 步骤 9 中的图像 2,2
      • Using your hands, lift the keyboard up from the top towards yourself until the keyboard is resting in your hand.
      • Do not aggressively pull at the keyboard for risk of ripping the connector cable.
      询问修复机器人
      添加评论
    7. HP Pavilion zv5000 Keyboard Replacement: 步骤 10 中的图像 1,2 HP Pavilion zv5000 Keyboard Replacement: 步骤 10 中的图像 2,2
      • Gently slide out the connecting cable from the laptop to the keyboard.
      • Do not aggressively pull at the connecting cable.
      询问修复机器人
      添加评论
    8. HP Pavilion zv5000 Keyboard Replacement: 步骤 11 中的图像 1,1
      • Completely remove the keyboard from the rest of the laptop.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Eliza Marks
于10/18/16注册
676 声望
创作了5篇指南
团队
UMass Dartmouth, Team 4-6, Catania Fall 2016 UMass Dartmouth, Team 4-6, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G6
3 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 35
总计 1,301
