跳转到主内容
加入维修社区 - 创建账户
HP Pavilion 17 TS RAM Replacement
你所需要的
    1. HP Pavilion 17 TS RAM Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion 17 TS RAM Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion 17 TS RAM Replacement, Battery: 步骤 1 中的图像 3,3
      • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
      询问修复机器人
      添加评论
    1. HP Pavilion 17 TS RAM Replacement, Rear Cover: 步骤 2 中的图像 1,3 HP Pavilion 17 TS RAM Replacement, Rear Cover: 步骤 2 中的图像 2,3 HP Pavilion 17 TS RAM Replacement, Rear Cover: 步骤 2 中的图像 3,3
      • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
      • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
      • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
      添加评论
    1. HP Pavilion 17 TS RAM Replacement, RAM: 步骤 3 中的图像 1,3 HP Pavilion 17 TS RAM Replacement, RAM: 步骤 3 中的图像 2,3 HP Pavilion 17 TS RAM Replacement, RAM: 步骤 3 中的图像 3,3
      在这个步骤中使用的工具:
      • On each side of each RAM card, there will be a thin strip of metal that is holding the chip down. Using tweezers or another thin tool, gently push these pins apart.
      • The first RAM card should pop up on its own. Gently remove this card, and look for the two strips of metal holding the bottom card down.
      • Push the pins apart just like for card one. Just like the first card, this one will pop up and you can remove it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Eric Sowersby
于03/25/16注册
413 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-6, Miles Spring 2016 UMass Dartmouth, Team 1-6, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G6
3 名成员
创作了59篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 22
总计 938
