跳转到主内容
加入维修社区 - 创建账户
HP Pavilion 17 TS Keyboard Replacement
你所需要的
  1. HP Pavilion 17 TS Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion 17 TS Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion 17 TS Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
    询问修复机器人
    添加评论
  2. HP Pavilion 17 TS Keyboard Replacement, Rear Cover: 步骤 2 中的图像 1,3 HP Pavilion 17 TS Keyboard Replacement, Rear Cover: 步骤 2 中的图像 2,3 HP Pavilion 17 TS Keyboard Replacement, Rear Cover: 步骤 2 中的图像 3,3
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
    添加评论
  3. HP Pavilion 17 TS Keyboard Replacement, RAM: 步骤 3 中的图像 1,3 HP Pavilion 17 TS Keyboard Replacement, RAM: 步骤 3 中的图像 2,3 HP Pavilion 17 TS Keyboard Replacement, RAM: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • On each side of each RAM card, there will be a thin strip of metal that is holding the chip down. Using tweezers or another thin tool, gently push these pins apart.
    • The first RAM card should pop up on its own. Gently remove this card, and look for the two strips of metal holding the bottom card down.
    • Push the pins apart just like for card one. Just like the first card, this one will pop up and you can remove it.
    询问修复机器人
    添加评论
  4. HP Pavilion 17 TS Keyboard Replacement, Wireless Card: 步骤 4 中的图像 1,3 HP Pavilion 17 TS Keyboard Replacement, Wireless Card: 步骤 4 中的图像 2,3 HP Pavilion 17 TS Keyboard Replacement, Wireless Card: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Undo the two clips attached to the wifi chip by pulling up gently with a pair of tweezers.
    • Unscrew the 9mm phillips screw holding the wifi chip in place.
    • Gently remove the wifi chip from its socket and place it to the side.
    询问修复机器人
    添加评论
  5. HP Pavilion 17 TS Keyboard Replacement, Disk Drive: 步骤 5 中的图像 1,3 HP Pavilion 17 TS Keyboard Replacement, Disk Drive: 步骤 5 中的图像 2,3 HP Pavilion 17 TS Keyboard Replacement, Disk Drive: 步骤 5 中的图像 3,3
    • With the battery compartment closest to you, there will be a 9mm screw next in the center-right of the back plate, labeled with a keyboard symbol and a disk symbol. Remove this phillips screw.
    • In the opening next to the screw, gently push out against the disk drive, and remove it from the disk drive compartment.
    询问修复机器人
    添加评论
  6. HP Pavilion 17 TS Keyboard Replacement, Hard Drive: 步骤 6 中的图像 1,3 HP Pavilion 17 TS Keyboard Replacement, Hard Drive: 步骤 6 中的图像 2,3 HP Pavilion 17 TS Keyboard Replacement, Hard Drive: 步骤 6 中的图像 3,3
    • Remove the two silver phillips screws from the hard drive.
    • Using the plastic tab, remove the hard drive from its socket.
    • Unplug the hard drive from the wire connecting it to the motherboard.
    询问修复机器人
    添加评论
  7. HP Pavilion 17 TS Keyboard Replacement, Keyboard: 步骤 7 中的图像 1,3 HP Pavilion 17 TS Keyboard Replacement, Keyboard: 步骤 7 中的图像 2,3 HP Pavilion 17 TS Keyboard Replacement, Keyboard: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Unscrew each marked 9mm screw on the rear plate. This will allow you to pull the keyboard off.
    • With a pair of tweezers or other thin object, push in and slightly to the left (away from the disk drive compartment). On the face of the computer (the keyboard side), you will see part of the keyboard get pushed up. Using the spudger, wedge the keyboard and slide the spudger along all four corners.
    • If you meet alot of resistance, go back and make sure you have undone every screw marked with a keyboard symbol.
    • Once the keyboard has been popped out, using the tweezers, undo the latch locking the keyboard's ribbon cable in place. Then remove the keyboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Eric Sowersby
于03/25/16注册
413 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-6, Miles Spring 2016 UMass Dartmouth, Team 1-6, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G6
3 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 2,823
