简介
Use this guide to replace the random-access memory (RAM) stick(s) in a HP Pavilion 15-cc561st (product number 1KU29UA).
The RAM stick is used by your laptop to temporarily store instructions and data, and your laptop will not work without this component.
If upon turning on the computer, the caps lock light has three long blinks, followed by two short blinks, then there is a potential memory failure. Use this guide to reseat or replace the memory module.
Update to the latest BIOS before adding new memory. Failing to update to the latest BIOS prior to installing new memory may result in various system problems. The most recent BIOS is available on HP's website. Download and run the file, and follow the on-screen instructions.
If only one memory module is installed, it must be installed in the socket that is closer to the center of the computer.
See the device page for supported memory configurations.
Shut down the laptop, disconnect all external devices, and unplug the AC adapter before beginning. Take the appropriate precautions if your battery is swollen.
你所需要的
在这个步骤中使用的工具:Magnetic Project Mat$19.95
Use a Phillips #0 screwdriver to remove five screws from the bottom cover:
Two 5.6 mm screws
Three 5.8 mm screws
Use a Phillips #0 screwdriver to remove the five 5.7 mm screws that secure the battery.
