跳转到主内容
加入维修社区 - 创建账户
HP Pavilion 14-v062us Keyboard Replacement
你所需要的
    1. HP Pavilion 14-v062us Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion 14-v062us Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
      • Power laptop off and make sure it is not plugged into charger
      • Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
      询问修复机器人
      添加评论
    2. HP Pavilion 14-v062us Keyboard Replacement: 步骤 2 中的图像 1,2 HP Pavilion 14-v062us Keyboard Replacement: 步骤 2 中的图像 2,2
      • Lift the battery upwards and out from the laptop
      询问修复机器人
      添加评论
    1. HP Pavilion 14-v062us Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,3 HP Pavilion 14-v062us Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,3 HP Pavilion 14-v062us Keyboard Replacement, Keyboard: 步骤 3 中的图像 3,3
      • Remove rectangular rubber tops with a spudger
      • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
      • Remove plastic edge covering with the blue plastic opening tool.
      • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
      询问修复机器人
      添加评论
    2. HP Pavilion 14-v062us Keyboard Replacement: 步骤 4 中的图像 1,2 HP Pavilion 14-v062us Keyboard Replacement: 步骤 4 中的图像 2,2
      • Use Phillips screwdriver #1
      • Remove all nine 7.09 mm PH#1 screw black screws including small rectangular cover.
      • Remove the three 7.14 mm PH#1 screws.
      • Remove the one 7.09 mm PH#1 screw that will be underneath the small rectangular cover
      询问修复机器人
      添加评论
    3. HP Pavilion 14-v062us Keyboard Replacement: 步骤 5 中的图像 1,2 HP Pavilion 14-v062us Keyboard Replacement: 步骤 5 中的图像 2,2
      • Remove disc tray
      • Locate screw within computer that is inside of where the disc tray was
      • Using a Phillips #1 screwdriver, unscrew the screw
      • Set laptop down and open laptop so the keyboard is facing you
      询问修复机器人
      添加评论
    4. HP Pavilion 14-v062us Keyboard Replacement: 步骤 6 中的图像 1,3 HP Pavilion 14-v062us Keyboard Replacement: 步骤 6 中的图像 2,3 HP Pavilion 14-v062us Keyboard Replacement: 步骤 6 中的图像 3,3
      • Using a spudger or plastic opening tool, pry along siding of keyboard, where it connects to the rest of the laptop
      • Pry until you are able to lift entire face and keyboard
      • Only cables should be connecting it underneath
      询问修复机器人
      添加评论
    5. HP Pavilion 14-v062us Keyboard Replacement: 步骤 7 中的图像 1,3 HP Pavilion 14-v062us Keyboard Replacement: 步骤 7 中的图像 2,3 HP Pavilion 14-v062us Keyboard Replacement: 步骤 7 中的图像 3,3
      • Disconnect/ unplug cables using plastic opening tool.
      • Separate the keyboard panel from the laptop with your hands.
      • Turn around the laptop and lay it flat.
      询问修复机器人
      添加评论
    6. HP Pavilion 14-v062us Keyboard Replacement: 步骤 8 中的图像 1,2 HP Pavilion 14-v062us Keyboard Replacement: 步骤 8 中的图像 2,2
      • Use a spudger to pry around the first layer of the silver panel until you are able to remove it
      • Only use a metal spudger as a last resort
      询问修复机器人
      添加评论
    7. HP Pavilion 14-v062us Keyboard Replacement: 步骤 9 中的图像 1,3 HP Pavilion 14-v062us Keyboard Replacement: 步骤 9 中的图像 2,3 HP Pavilion 14-v062us Keyboard Replacement: 步骤 9 中的图像 3,3
      • Using a spudger tool, start prying around the second layer of the silver panel until you are able to remove it
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
2指南评论
Thank you so much, this guide is very helpful.
Rodolfo Trujillo - 回复 分享
Thank you for the guide. It was very helpful!
dmitryp80 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 30
总计 2,408
