跳转到主内容
加入维修社区 - 创建账户
HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement
你所需要的
    1. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Battery and Service Access Cover: 步骤 1 中的图像 1,1
      • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
      • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
      询问修复机器人
      添加评论
    2. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 2 中的图像 1,3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 2 中的图像 2,3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 2 中的图像 3,3
      • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
      • Slide the battery release latch inwards.
      • Pull the battery towards you to remove it.
      询问修复机器人
      添加评论
    3. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 3 中的图像 1,3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 3 中的图像 2,3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 3 中的图像 3,3
      • Slide the service access cover release lever to the right.
      • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
      询问修复机器人
      添加评论
    4. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 4 中的图像 1,1
      • Orient the computer as shown in the picture.
      询问修复机器人
      添加评论
    1. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): 步骤 5 中的图像 1,2 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): 步骤 5 中的图像 2,2
      • Locate the Wi-Fi Card (WLAN Module), near the computer's bottom left corner.
      询问修复机器人
      添加评论
    2. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 6 中的图像 1,3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 6 中的图像 2,3 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 6 中的图像 3,3
      • Disconnect the two cables from the Wi-Fi card by gently lifting them away from the card.
      • There should be two black cables, one labeled with a white sticker, connected to the module.
      询问修复机器人
      添加评论
    3. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 7 中的图像 1,1
      • Remove the two 2.0 x 3.0 screws securing the Wi-Fi card using a Phillips #00 screwdriver
      • The card should tilt up away from the laptop at an angle after removing the screws.
      询问修复机器人
      添加评论
    4. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: 步骤 8 中的图像 1,1
      • Remove the Wi-Fi card by gently pulling it out of its slot at an angle.
      • Potential for device damage: Be sure to pull gently and at an angle away from you. If the card is pulled straight up, there is a chance it could break or bend.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Taylor
于10/05/12注册
116 声望
撰写一个指南
团队
Cal Poly, Team 3-23, Amido Fall 2012 Cal Poly, Team 3-23, Amido Fall 2012 的会员
CPSU-AMIDO-F12S3G23
4 名成员
创作了54篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 1,587
