跳转到主内容
加入维修社区 - 创建账户
HP Mini 210 Hard Drive Replacement
你所需要的
  1. HP Mini 210 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP Mini 210 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
    询问修复机器人
    添加评论
  2. HP Mini 210 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out from the netbook.
    询问修复机器人
    添加评论
  3. HP Mini 210 Hard Drive Replacement, Disassembling HP Mini 210 Back Case: 步骤 3 中的图像 1,1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
    询问修复机器人
    添加评论
  4. HP Mini 210 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
    询问修复机器人
    添加评论
  5. HP Mini 210 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Pull the back case off from the front edge.
    询问修复机器人
    添加评论
  6. HP Mini 210 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Peel back the black sticker covering the hard drive with tweezers or your fingers.
    询问修复机器人
    添加评论
  7. HP Mini 210 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Use a plastic opening tool to carefully disconnect the hard drive connector found above the RAM slot.
    询问修复机器人
    添加评论
  8. HP Mini 210 Hard Drive Replacement: 步骤 8 中的图像 1,2 HP Mini 210 Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Pull the silver plastic tab up and remove the hard drive. The tab may also be black.
    • Be aware of the 4 foam cushions on each corner of the hard drive as they may become loose during removal.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
14等其他人完成本指南。
团队
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G17
3 名成员
创作了8篇指南
1指南评论
Be aware that some models don't have buttons but a orange switch that need some pressure to release the cover
Alejandro - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 84
总计 19,249
