跳转到主内容
加入维修社区 - 创建账户
HP Mini 210 CMOS Battery Replacement
你所需要的
  1. HP Mini 210 CMOS Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Mini 210 CMOS Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
    询问修复机器人
    添加评论
  2. HP Mini 210 CMOS Battery Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out from the netbook.
    询问修复机器人
    添加评论
  3. HP Mini 210 CMOS Battery Replacement, Disassembling HP Mini 210 Back Case: 步骤 3 中的图像 1,1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
    询问修复机器人
    添加评论
  4. HP Mini 210 CMOS Battery Replacement: 步骤 4 中的图像 1,1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
    询问修复机器人
    添加评论
  5. HP Mini 210 CMOS Battery Replacement: 步骤 5 中的图像 1,1
    • Pull the back case off from the front edge.
    询问修复机器人
    添加评论
  6. HP Mini 210 CMOS Battery Replacement, CMOS Battery: 步骤 6 中的图像 1,1
    • Cut one side of the black adhesive ribbon on top of the CMOS battery with a utility blade.
    • Be careful not to scratch or damage the battery or netbook, and be sure to keep your fingers out of the way!
    询问修复机器人
    添加评论
  7. HP Mini 210 CMOS Battery Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • Slowly peel back the black adhesive ribbon with tweezers.
    询问修复机器人
    添加评论
  8. HP Mini 210 CMOS Battery Replacement: 步骤 8 中的图像 1,1
    • Pry the CMOS battery out with a plastic opening tool.
    询问修复机器人
    添加评论
  9. HP Mini 210 CMOS Battery Replacement: 步骤 9 中的图像 1,1
    • Pop the CMOS battery out.
    • When reinstalling, insert the battery back into the slot with the positive terminal facing up.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
团队
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G17
3 名成员
创作了8篇指南
2指南评论
after need CMOS reset. Screen is black. Is there an easy way on my HP Mini 210?
Carl Louviere - 回复 分享
Very good tut. Now my HP Mini 210 can get the right time xD
Byte Core - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 84
总计 17,099
