跳转到主内容
加入维修社区 - 创建账户
HP G72 Memory Module Replacement
你所需要的
  1. HP G72 Memory Module Replacement, Memory Module: 步骤 1 中的图像 1,3 HP G72 Memory Module Replacement, Memory Module: 步骤 1 中的图像 2,3 HP G72 Memory Module Replacement, Memory Module: 步骤 1 中的图像 3,3
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
    • Loosen the three Phillips M2.5×6.0 captive screws that secure the memory module compartment cover.
  2. HP G72 Memory Module Replacement: 步骤 2 中的图像 1,3 HP G72 Memory Module Replacement: 步骤 2 中的图像 2,3 HP G72 Memory Module Replacement: 步骤 2 中的图像 3,3
    • Use a plastic opening tool (or equivalent) to lift the back side of the cover. Small tabs hold the cover in place. Firmly pull up on the cover to release the tabs.
    • Remove the cover
    • Spread the retaining tabs on each side of the memory module slot to release the memory module. Remove the module as needed
结论
2等其他人完成本指南。
oldturkey03
于09/29/10注册
839,347 声望
创作了123篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 20
总计 2,715
