简介
To work on this laptop, or any other device, it is important to shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn on the computer, and then shut it down through the operating system. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
你所需要的
Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
Turn the computer so that it faces upside down. Position the computer with the front toward you.
Slide the battery release latch to release the battery. Pivot the battery to remove it.
11等其他人完成本指南。
一条评论
Use a #1 Phillips, #0 in a pinch - #00 is too small. Also my G72 has different screw locations holding on the memory and hard drive covers. Mine also does not require removing the hard drive cover. The necessary screw locations are marked with a little keyboard icon.
Apart from the variations, good article with decent illustrations. Anyone willing to tackle the job should be able to do it in fifteen minutes or less.
