跳转到主内容
加入维修社区 - 创建账户
HP G60T-600 CTO Power Button Frame Replacement
你所需要的
    1. HP G60T-600 CTO Power Button Frame Replacement, Battery: 步骤 1 中的图像 1,1
      • Failure to remove the battery before performing any replacement guide may result in electric shock.
      • Close your device, then turn it over.
      询问修复机器人
      添加评论
    2. HP G60T-600 CTO Power Button Frame Replacement: 步骤 2 中的图像 1,2 HP G60T-600 CTO Power Button Frame Replacement: 步骤 2 中的图像 2,2
      • Place your index finger on the ridged tab.
      询问修复机器人
      添加评论
    3. HP G60T-600 CTO Power Button Frame Replacement: 步骤 3 中的图像 1,1
      • Apply moderate pressure to the tab and slide it to the right.
      • While the tab is on the right, you should be able to gently slide your battery out of your device.
      询问修复机器人
      添加评论
    1. HP G60T-600 CTO Power Button Frame Replacement, Keyboard: 步骤 4 中的图像 1,2 HP G60T-600 CTO Power Button Frame Replacement, Keyboard: 步骤 4 中的图像 2,2
      • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
      询问修复机器人
      添加评论
    2. HP G60T-600 CTO Power Button Frame Replacement: 步骤 5 中的图像 1,1
      • Turn your laptop over and open it up.
      • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
      询问修复机器人
      添加评论
    3. HP G60T-600 CTO Power Button Frame Replacement: 步骤 6 中的图像 1,1
      • Pull up on the top of your keyboard with medium force. It should start to pop out.
      • A plastic opening tool may facilitate this task.
      • Run your hands underneath the edges of the keyboard until it is free from the device.
      • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
      询问修复机器人
      添加评论
    4. HP G60T-600 CTO Power Button Frame Replacement: 步骤 7 中的图像 1,2 HP G60T-600 CTO Power Button Frame Replacement: 步骤 7 中的图像 2,2
      • Place your thumbs on the two small, white tabs.
      • Push these tabs forward to release the connection and free the keyboard from the device.
      询问修复机器人
      添加评论
    1. HP G60T-600 CTO Power Button Frame Replacement, Power Button Frame: 步骤 8 中的图像 1,1
      • Similarly to how you remove the keyboard, gently pry a small section of the power button frame up.
      询问修复机器人
      添加评论
    2. HP G60T-600 CTO Power Button Frame Replacement: 步骤 9 中的图像 1,2 HP G60T-600 CTO Power Button Frame Replacement: 步骤 9 中的图像 2,2
      • Gently pull the white tab upwards.
      • With similar force, pull the connection out.
      • You are now free to pull the power button frame off of your device.
      询问修复机器人
      添加评论
    3. HP G60T-600 CTO Power Button Frame Replacement: 步骤 10 中的图像 1,1
      • Unscrew the 5mm screw holding the CD player in place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 4-5, Catania Fall 2016 UMass Dartmouth, Team 4-5, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G5
3 名成员
创作了54篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 28
总计 412
