跳转到主内容
加入维修社区 - 创建账户
HP Flyer Red Battery Replacement
    1. HP Flyer Red Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Flyer Red Battery Replacement, Battery: 步骤 1 中的图像 2,2
      • Make sure your laptop is powered off.
      • With laptop closed flip to look at the underside of the laptop.
      询问修复机器人
      添加评论
    2. HP Flyer Red Battery Replacement: 步骤 2 中的图像 1,1
      • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
      询问修复机器人
      添加评论
    3. HP Flyer Red Battery Replacement: 步骤 3 中的图像 1,2 HP Flyer Red Battery Replacement: 步骤 3 中的图像 2,2
      • The left switch is the battery unlock switch.
      • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
      询问修复机器人
      添加评论
    4. HP Flyer Red Battery Replacement: 步骤 4 中的图像 1,1
      • Then take and slide the other switch to the other end of its track which will pop out the battery.
      • Grab the battery and pull it out of the slot.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
1指南评论
What do you do when the battery not charging but the laptop is working when directly plugged on power
liberty siegmann derera - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 2,757
