跳转到主内容
HP Envy x360 m6-w103dx Fan Replacement
你所需要的
  1. HP Envy x360 m6-w103dx Fan Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Envy x360 m6-w103dx Fan Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Fan Replacement: 步骤 2 中的图像 1,2 HP Envy x360 m6-w103dx Fan Replacement: 步骤 2 中的图像 2,2
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Fan Replacement: 步骤 3 中的图像 1,3 HP Envy x360 m6-w103dx Fan Replacement: 步骤 3 中的图像 2,3 HP Envy x360 m6-w103dx Fan Replacement: 步骤 3 中的图像 3,3
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Fan Replacement: 步骤 4 中的图像 1,3 HP Envy x360 m6-w103dx Fan Replacement: 步骤 4 中的图像 2,3 HP Envy x360 m6-w103dx Fan Replacement: 步骤 4 中的图像 3,3
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Fan Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Disconnect the pin head battery connection to remove power from the motherboard.
    • Unscrew the five 4mm screws holding the motherboard in place using a #0 Phillips screwdriver.
    • It's possible the positions of the screws will be different on your board. If the motherboard resists lifting, double-check that all screws have been removed.
  6. HP Envy x360 m6-w103dx Fan Replacement: 步骤 6 中的图像 1,3 HP Envy x360 m6-w103dx Fan Replacement: 步骤 6 中的图像 2,3 HP Envy x360 m6-w103dx Fan Replacement: 步骤 6 中的图像 3,3
    • Remove the five flat ribbon cables by gently lifting the head of the cable up and back.
    • Remove the two remaining multicolored ribbon cables by pulling the white plastic head backwards.
    • Do not pull directly on the wires.
    • If the head of the multicolored ribbon cable doesn't come out, try gently wiggling it side to side as you pull.
  7. HP Envy x360 m6-w103dx Fan Replacement: 步骤 7 中的图像 1,3 HP Envy x360 m6-w103dx Fan Replacement: 步骤 7 中的图像 2,3 HP Envy x360 m6-w103dx Fan Replacement: 步骤 7 中的图像 3,3
    • Lift the motherboard up from the left side at a shallow angle.
    • Gently pull the motherboard to the left and gently wiggle it side to side until the ports on the right side of the board detach from the case.
    • Ensure the laptop is well supported, as the motherboard is a heavy component and removing it may make the laptop off-balance.
  8. HP Envy x360 m6-w103dx Fan Replacement, Fan: 步骤 8 中的图像 1,2 HP Envy x360 m6-w103dx Fan Replacement, Fan: 步骤 8 中的图像 2,2
    • Carefully lay the motherboard on a flat surface with the metal plate facing up.
    • Unscrew the four 6.0 mm screws from the heatsink using a #00 Phillips screwdriver.
    • The screws do not detach from the component, just the motherboard.
  9. HP Envy x360 m6-w103dx Fan Replacement: 步骤 9 中的图像 1,1
    • Disconnect the fan pin-head connector.
  10. HP Envy x360 m6-w103dx Fan Replacement: 步骤 10 中的图像 1,3 HP Envy x360 m6-w103dx Fan Replacement: 步骤 10 中的图像 2,3 HP Envy x360 m6-w103dx Fan Replacement: 步骤 10 中的图像 3,3
    • Carefully lift the fan assembly and pull away from the motherboard.
    • When reassembling, be sure to clean the old thermal paste from the heatsink and CPU contact points. Then, reapply new thermal paste with our How to Apply Thermal Paste guide.
结论
另外一个人完成了本指南。
Steven Ngo
于10/10/19注册
927 声望
创作了7篇指南
团队
Cal Poly, Team S12-G2, Regan Fall 2019 Cal Poly, Team S12-G2, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G2
4 名成员
创作了23篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 557
