跳转到主内容
加入维修社区 - 创建账户
HP Envy TouchSmart 15 Wireless Adapter Replacement
你所需要的
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: 步骤 1 中的图像 1,1
    • Press the battery release tab and the battery will pop up.
    询问修复机器人
    添加评论
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the laptop, it will come out easily.
    询问修复机器人
    添加评论
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: 步骤 3 中的图像 1,2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: 步骤 3 中的图像 2,2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
    询问修复机器人
    添加评论
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 4 中的图像 1,3 HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 4 中的图像 2,3 HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 4 中的图像 3,3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
    询问修复机器人
    添加评论
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: 步骤 5 中的图像 1,2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: 步骤 5 中的图像 2,2
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
    询问修复机器人
    添加评论
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 6 中的图像 1,3 HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 6 中的图像 2,3 HP Envy TouchSmart 15 Wireless Adapter Replacement: 步骤 6 中的图像 3,3
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G6
4 名成员
创作了10篇指南
1指南评论
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 32
总计 3,642
