跳转到主内容
加入维修社区 - 创建账户
HP Envy TouchSmart 15 Fan Replacement
你所需要的
    1. HP Envy TouchSmart 15 Fan  Replacement, Battery: 步骤 1 中的图像 1,1
      • Press the battery release tab and the battery will pop up.
      询问修复机器人
      添加评论
    2. HP Envy TouchSmart 15 Fan  Replacement: 步骤 2 中的图像 1,1
      • Remove the battery from the laptop, it will come out easily.
      询问修复机器人
      添加评论
    1. HP Envy TouchSmart 15 Fan  Replacement, Accessory Plate: 步骤 3 中的图像 1,2 HP Envy TouchSmart 15 Fan  Replacement, Accessory Plate: 步骤 3 中的图像 2,2
      • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
      询问修复机器人
      添加评论
    2. HP Envy TouchSmart 15 Fan  Replacement: 步骤 4 中的图像 1,3 HP Envy TouchSmart 15 Fan  Replacement: 步骤 4 中的图像 2,3 HP Envy TouchSmart 15 Fan  Replacement: 步骤 4 中的图像 3,3
      • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
      询问修复机器人
      添加评论
    1. HP Envy TouchSmart 15 Fan  Replacement, Solid State Drive: 步骤 5 中的图像 1,2 HP Envy TouchSmart 15 Fan  Replacement, Solid State Drive: 步骤 5 中的图像 2,2
      • Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
      • After you have removed the screw, the Solid State Drive should lift up.
      询问修复机器人
      添加评论
    2. HP Envy TouchSmart 15 Fan  Replacement: 步骤 6 中的图像 1,2 HP Envy TouchSmart 15 Fan  Replacement: 步骤 6 中的图像 2,2
      • Very carefully, remove the SSD by gently pulling away from the SSD socket.
      询问修复机器人
      添加评论
    1. HP Envy TouchSmart 15 Fan  Replacement, Hard Drive: 步骤 7 中的图像 1,2 HP Envy TouchSmart 15 Fan  Replacement, Hard Drive: 步骤 7 中的图像 2,2
      • Use the plastic opening tool to pry the hard drive away from the board. Notice that there is a slit centered at the back of where the hard drive is sitting. This is where you'll insert the plastic opening tool as shown in the photo. Finally, pry with the plastic opening tool to remove the hard drive.
      询问修复机器人
      添加评论
    2. HP Envy TouchSmart 15 Fan  Replacement: 步骤 8 中的图像 1,2 HP Envy TouchSmart 15 Fan  Replacement: 步骤 8 中的图像 2,2
      • Firmly grasp the connector's base as shown and pull to remove from the hard drive.
      询问修复机器人
      添加评论
    1. HP Envy TouchSmart 15 Fan  Replacement, Back Plate: 步骤 9 中的图像 1,3 HP Envy TouchSmart 15 Fan  Replacement, Back Plate: 步骤 9 中的图像 2,3 HP Envy TouchSmart 15 Fan  Replacement, Back Plate: 步骤 9 中的图像 3,3
      • Remove the highlighted rubber stoppers with a metal spudger as pictured. They should expose a screw that you will need to remove in a later step.
      询问修复机器人
      添加评论
    2. HP Envy TouchSmart 15 Fan  Replacement: 步骤 10 中的图像 1,3 HP Envy TouchSmart 15 Fan  Replacement: 步骤 10 中的图像 2,3 HP Envy TouchSmart 15 Fan  Replacement: 步骤 10 中的图像 3,3
      • Remove plastic cover highlighted. It should expose a screw that you will need in a later step.
      询问修复机器人
      添加评论
    3. HP Envy TouchSmart 15 Fan  Replacement: 步骤 11 中的图像 1,1
      • Remove all highlighted screws with PH 1 screwdriver. These screws are PM 2.0x2.5.
      询问修复机器人
      添加评论
    4. HP Envy TouchSmart 15 Fan  Replacement: 步骤 12 中的图像 1,2 HP Envy TouchSmart 15 Fan  Replacement: 步骤 12 中的图像 2,2
      • Remove all highlighted screws from the battery access area. These are PM 1.5x2.0 screws
      添加评论
    5. HP Envy TouchSmart 15 Fan  Replacement: 步骤 13 中的图像 1,1
      • Remove screws highlighted with PH1 screwdriver from accessory plate area.These are PM 2.5x3.0 screws
      • Remove screws highlighted with PH1 screwdriver from accessory plate area. These are PM 2.5x4.5 screws
      询问修复机器人
      添加评论
    6. HP Envy TouchSmart 15 Fan  Replacement: 步骤 14 中的图像 1,3 HP Envy TouchSmart 15 Fan  Replacement: 步骤 14 中的图像 2,3 HP Envy TouchSmart 15 Fan  Replacement: 步骤 14 中的图像 3,3
      • Pry open back plate area with plastic opening tool. The back plate should pry open with relative ease. If you feel some resistance at any point please refer to steps 2-5 because a screw has probably been missed.
      添加评论
    1. HP Envy TouchSmart 15 Fan  Replacement, Fan: 步骤 15 中的图像 1,2 HP Envy TouchSmart 15 Fan  Replacement, Fan: 步骤 15 中的图像 2,2
      • There are 3 screws holding the fan in place. These are PM 2.5x4.5 screws
      添加评论
    2. HP Envy TouchSmart 15 Fan  Replacement: 步骤 16 中的图像 1,2 HP Envy TouchSmart 15 Fan  Replacement: 步骤 16 中的图像 2,2
      • There are 3 strips of tape. Remove them with your hand.
      询问修复机器人
      添加评论
    3. HP Envy TouchSmart 15 Fan  Replacement: 步骤 17 中的图像 1,1
      • Remove the fan by sliding it out and pulling it upwards. Set the fan off to the side to reveal the connector.
      添加评论
    4. HP Envy TouchSmart 15 Fan  Replacement: 步骤 18 中的图像 1,2 HP Envy TouchSmart 15 Fan  Replacement: 步骤 18 中的图像 2,2
      • Remove the black connector from the white insert shown at the center of the picture just below the fingers pinching the black connector.
      • The connector will come out straight up.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
21等其他人完成本指南。
团队
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G6
4 名成员
创作了90篇指南
13指南评论
TY. excellent write up =)
Rameez Aftab - 回复 分享
TY good write up I did not have an SSD drive . Some of the screw locations were slightly different [I suppose they very by configuration].
I meticulously followed your instructions. I did have trouble reconnecting the hard drive but it was my lack of experience and a good magnifying glass. Problem fixed. Fan working great.
Really appreciate your photos and explanation
jkbushtx - 回复 分享
Excellent directions. Great pictures. Everything was as specified in the instructions. Original fan had a piece of broken plastic in it Removed and reassembled, works great. Make sure flat lead for hard drive is correctly installed.
fischer.jim59 - 回复 分享
This was seriously better than any YouTube video ever. It worked like a charm period thank you so much.
Ginger Grant - 回复 分享
Excellent walk thru... best I've ever seen!
Julie Baker - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 24
总计 14,734
