跳转到主内容
加入维修社区 - 创建账户
HP Elitebook 820 G2 RAM Replacement
  1. HP Elitebook 820 G2 RAM Replacement, Back Panel: 步骤 1 中的图像 1,2 HP Elitebook 820 G2 RAM Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Slide the lever firmly to the left on the back panel.
    • Once the back panel is unlocked, there should be red showing to the right of the lever.
    添加评论
  2. HP Elitebook 820 G2 RAM Replacement: 步骤 2 中的图像 1,2 HP Elitebook 820 G2 RAM Replacement: 步骤 2 中的图像 2,2
    • Slide the back panel towards you.
    • Lift the back panel to remove it.
    询问修复机器人
    添加评论
  3. HP Elitebook 820 G2 RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • Undo the clips on the sides of the RAM chips by pushing them away from the RAM.
    • Too much pressure might snap the clips.
    询问修复机器人
    添加评论
  4. HP Elitebook 820 G2 RAM Replacement: 步骤 4 中的图像 1,1
    • Once the clips are unfastened, use a plastic spudger to lightly pry up the RAM chips.
    • Grab the RAM chips, remove them, and set them aside.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
1指南评论
Hi KaitLyn Teubert
Thank you for your HP Elitebook 820 G2 RAM Replacement tutorial
Currently, I have 2 HP Elitebook 820 G2 notebook, and I have problem with one of my HP Elitebook 820 G2.
RAM is not detected. I have tried to replace the RAM to another HP Elitebook 820 G2, and also buy new RAM but its doesn't work at all.
May you have any suggestion to my problem?
Thank you.
Jaya Ma - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 43
总计 2,343
