跳转到主内容
HP EliteBook x360 830 G6 Battery Replacement
你所需要的
  1. HP EliteBook x360 830 G6 Battery Replacement, Unfasten the back cover: 步骤 1 中的图像 1,1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Battery Replacement, Release the clips: 步骤 2 中的图像 1,2 HP EliteBook x360 830 G6 Battery Replacement, Release the clips: 步骤 2 中的图像 2,2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Battery Replacement, Release the remaining clips: 步骤 3 中的图像 1,2 HP EliteBook x360 830 G6 Battery Replacement, Release the remaining clips: 步骤 3 中的图像 2,2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: 步骤 4 中的图像 1,3 HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: 步骤 4 中的图像 2,3 HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: 步骤 4 中的图像 3,3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: 步骤 5 中的图像 1,3 HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: 步骤 5 中的图像 2,3 HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: 步骤 5 中的图像 3,3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Battery Replacement, Unfasten the battery: 步骤 6 中的图像 1,1
    • Use your Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
  7. HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: 步骤 7 中的图像 1,3 HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: 步骤 7 中的图像 2,3 HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: 步骤 7 中的图像 3,3
    • Pull the battery out from the retaining tabs at the front of the chassis.
    • Remove the battery.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Clay Eickemeyer
于09/19/22注册
70,408 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,085篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 69
总计 2,063
