跳转到主内容
加入维修社区 - 创建账户
HP Compaq NC6120 Mouse Pad Replacement
你所需要的
  1. HP Compaq NC6120 Mouse Pad Replacement, Disassembling HP Compaq NC6120 Laptop: 步骤 1 中的图像 1,3 HP Compaq NC6120 Mouse Pad Replacement, Disassembling HP Compaq NC6120 Laptop: 步骤 1 中的图像 2,3 HP Compaq NC6120 Mouse Pad Replacement, Disassembling HP Compaq NC6120 Laptop: 步骤 1 中的图像 3,3
    • Flip laptop so the backside is facing upwards.
    • Pull the two plastic switches at the top of the backside of the computer outwards, and remove the battery.
    询问修复机器人
    添加评论
  2. HP Compaq NC6120 Mouse Pad Replacement: 步骤 2 中的图像 1,2 HP Compaq NC6120 Mouse Pad Replacement: 步骤 2 中的图像 2,2
    • Remove all 13 screws from the back panel of the computer (includes the two torx screws under the battery and the two under the ram memory panel).
    • Remove the four screws at the hinge of the computer (also attaching the back panel to the rest of the computer).
    • All screws are 9.8mm 3.0 flatheads except for the two under the battery which are T9 torx.
    添加评论
  3. HP Compaq NC6120 Mouse Pad Replacement: 步骤 3 中的图像 1,2 HP Compaq NC6120 Mouse Pad Replacement: 步骤 3 中的图像 2,2
    • Open up the laptop so that the screen is facing towards you. Push the monitor back until it is flat, parallel to the keyboard.
    询问修复机器人
    添加评论
  4. HP Compaq NC6120 Mouse Pad Replacement: 步骤 4 中的图像 1,2 HP Compaq NC6120 Mouse Pad Replacement: 步骤 4 中的图像 2,2
    • Using the iFixit opening tool, remove the plastic panel located between the keyboard and monitor. It should pop off easily with the spudger and can then be pulled away.
    询问修复机器人
    添加评论
  5. HP Compaq NC6120 Mouse Pad Replacement: 步骤 5 中的图像 1,2 HP Compaq NC6120 Mouse Pad Replacement: 步骤 5 中的图像 2,2
    • Remove the white cable attached to the just-removed plastic panel from the motherboard.
    询问修复机器人
    添加评论
  6. HP Compaq NC6120 Mouse Pad Replacement: 步骤 6 中的图像 1,2 HP Compaq NC6120 Mouse Pad Replacement: 步骤 6 中的图像 2,2
    • Flip the keyboard away from the monitor, rotating it so that the keys are face down on the mousepad. Remove the black cord at the bottom of the keyboard that connects it to the motherboard. The keyboard is now free and can be removed.
    添加评论
  7. HP Compaq NC6120 Mouse Pad Replacement: 步骤 7 中的图像 1,3 HP Compaq NC6120 Mouse Pad Replacement: 步骤 7 中的图像 2,3 HP Compaq NC6120 Mouse Pad Replacement: 步骤 7 中的图像 3,3
    • Remove the two 9.8mm 3.0 flathead screws. There is one at each of the hinges.
    询问修复机器人
    添加评论
  8. HP Compaq NC6120 Mouse Pad Replacement: 步骤 8 中的图像 1,3 HP Compaq NC6120 Mouse Pad Replacement: 步骤 8 中的图像 2,3 HP Compaq NC6120 Mouse Pad Replacement: 步骤 8 中的图像 3,3
    • Unplug the black cable with rectangular white plastic head from the motherboard. It is located at the top left of the motherboard, directly below the left hinge.
    询问修复机器人
    添加评论
  9. HP Compaq NC6120 Mouse Pad Replacement: 步骤 9 中的图像 1,2 HP Compaq NC6120 Mouse Pad Replacement: 步骤 9 中的图像 2,2
    • Pull the monitor directly upwards from where it lay. The two metal hinges should easily slide out of their holes and the monitor will be disconnected from the motherboard.
    询问修复机器人
    添加评论
  10. HP Compaq NC6120 Mouse Pad Replacement: 步骤 10 中的图像 1,3 HP Compaq NC6120 Mouse Pad Replacement: 步骤 10 中的图像 2,3 HP Compaq NC6120 Mouse Pad Replacement: 步骤 10 中的图像 3,3
    • Using the iFixit opening tool, pry the black plastic panel (with mousepad) off of the motherboard.
    询问修复机器人
    添加评论
  11. HP Compaq NC6120 Mouse Pad Replacement: 步骤 11 中的图像 1,3 HP Compaq NC6120 Mouse Pad Replacement: 步骤 11 中的图像 2,3 HP Compaq NC6120 Mouse Pad Replacement: 步骤 11 中的图像 3,3
    • Unplug the white cord connecting the mousepad to the motherboard from the motherboard, and pull off the entire plastic panel.
    添加评论
  12. HP Compaq NC6120 Mouse Pad Replacement, Mouse Pad: 步骤 12 中的图像 1,1
    • Refer to the laptop disassembly guide.
    询问修复机器人
    添加评论
  13. HP Compaq NC6120 Mouse Pad Replacement: 步骤 13 中的图像 1,1
    • Find the green chip encased by an aluminum frame on the underside of the plastic panel that was removed last in the computer disassembly guide.
    询问修复机器人
    添加评论
  14. HP Compaq NC6120 Mouse Pad Replacement: 步骤 14 中的图像 1,1
    • Remove the two 3.5mm Phillips #00 screws located at the bottom of the aluminum frame.
    询问修复机器人
    添加评论
  15. HP Compaq NC6120 Mouse Pad Replacement: 步骤 15 中的图像 1,1
    • Slowly slide the frame in the direction of the keyboard hole on the plastic panel until the frame is released from the metal latches.
    询问修复机器人
    添加评论
  16. HP Compaq NC6120 Mouse Pad Replacement: 步骤 16 中的图像 1,1
    • Slowly remove the frame without tearing the black fabric.
    询问修复机器人
    添加评论
  17. HP Compaq NC6120 Mouse Pad Replacement: 步骤 17 中的图像 1,1
    • Carefully slide blue plastic connector on the mousepad towards the screw holes.
    询问修复机器人
    添加评论
  18. HP Compaq NC6120 Mouse Pad Replacement: 步骤 18 中的图像 1,1
    • Remove the mousepad.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Mateo Cuellar
于04/08/15注册
601 声望
创作了4篇指南
团队
Cal Poly, Team 17-4, Forte Spring 2015 Cal Poly, Team 17-4, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G4
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 33
总计 883
