跳转到主内容
加入维修社区 - 创建账户
HP Compaq NC6120 CD Drive Replacement
你所需要的
  1. HP Compaq NC6120 CD Drive Replacement, Disassembling HP Compaq NC6120 Laptop: 步骤 1 中的图像 1,3 HP Compaq NC6120 CD Drive Replacement, Disassembling HP Compaq NC6120 Laptop: 步骤 1 中的图像 2,3 HP Compaq NC6120 CD Drive Replacement, Disassembling HP Compaq NC6120 Laptop: 步骤 1 中的图像 3,3
    • Flip laptop so the backside is facing upwards.
    • Pull the two plastic switches at the top of the backside of the computer outwards, and remove the battery.
    询问修复机器人
    添加评论
  2. HP Compaq NC6120 CD Drive Replacement: 步骤 2 中的图像 1,2 HP Compaq NC6120 CD Drive Replacement: 步骤 2 中的图像 2,2
    • Remove all 13 screws from the back panel of the computer (includes the two torx screws under the battery and the two under the ram memory panel).
    • Remove the four screws at the hinge of the computer (also attaching the back panel to the rest of the computer).
    • All screws are 9.8mm 3.0 flatheads except for the two under the battery which are T9 torx.
    添加评论
  3. HP Compaq NC6120 CD Drive Replacement: 步骤 3 中的图像 1,2 HP Compaq NC6120 CD Drive Replacement: 步骤 3 中的图像 2,2
    • Open up the laptop so that the screen is facing towards you. Push the monitor back until it is flat, parallel to the keyboard.
    询问修复机器人
    添加评论
  4. HP Compaq NC6120 CD Drive Replacement: 步骤 4 中的图像 1,2 HP Compaq NC6120 CD Drive Replacement: 步骤 4 中的图像 2,2
    • Using the iFixit opening tool, remove the plastic panel located between the keyboard and monitor. It should pop off easily with the spudger and can then be pulled away.
    询问修复机器人
    添加评论
  5. HP Compaq NC6120 CD Drive Replacement: 步骤 5 中的图像 1,2 HP Compaq NC6120 CD Drive Replacement: 步骤 5 中的图像 2,2
    • Remove the white cable attached to the just-removed plastic panel from the motherboard.
    询问修复机器人
    添加评论
  6. HP Compaq NC6120 CD Drive Replacement: 步骤 6 中的图像 1,2 HP Compaq NC6120 CD Drive Replacement: 步骤 6 中的图像 2,2
    • Flip the keyboard away from the monitor, rotating it so that the keys are face down on the mousepad. Remove the black cord at the bottom of the keyboard that connects it to the motherboard. The keyboard is now free and can be removed.
    添加评论
  7. HP Compaq NC6120 CD Drive Replacement: 步骤 7 中的图像 1,3 HP Compaq NC6120 CD Drive Replacement: 步骤 7 中的图像 2,3 HP Compaq NC6120 CD Drive Replacement: 步骤 7 中的图像 3,3
    • Remove the two 9.8mm 3.0 flathead screws. There is one at each of the hinges.
    询问修复机器人
    添加评论
  8. HP Compaq NC6120 CD Drive Replacement: 步骤 8 中的图像 1,3 HP Compaq NC6120 CD Drive Replacement: 步骤 8 中的图像 2,3 HP Compaq NC6120 CD Drive Replacement: 步骤 8 中的图像 3,3
    • Unplug the black cable with rectangular white plastic head from the motherboard. It is located at the top left of the motherboard, directly below the left hinge.
    询问修复机器人
    添加评论
  9. HP Compaq NC6120 CD Drive Replacement: 步骤 9 中的图像 1,2 HP Compaq NC6120 CD Drive Replacement: 步骤 9 中的图像 2,2
    • Pull the monitor directly upwards from where it lay. The two metal hinges should easily slide out of their holes and the monitor will be disconnected from the motherboard.
    询问修复机器人
    添加评论
  10. HP Compaq NC6120 CD Drive Replacement: 步骤 10 中的图像 1,3 HP Compaq NC6120 CD Drive Replacement: 步骤 10 中的图像 2,3 HP Compaq NC6120 CD Drive Replacement: 步骤 10 中的图像 3,3
    • Using the iFixit opening tool, pry the black plastic panel (with mousepad) off of the motherboard.
    询问修复机器人
    添加评论
  11. HP Compaq NC6120 CD Drive Replacement: 步骤 11 中的图像 1,3 HP Compaq NC6120 CD Drive Replacement: 步骤 11 中的图像 2,3 HP Compaq NC6120 CD Drive Replacement: 步骤 11 中的图像 3,3
    • Unplug the white cord connecting the mousepad to the motherboard from the motherboard, and pull off the entire plastic panel.
    添加评论
  12. HP Compaq NC6120 CD Drive Replacement, CD Drive: 步骤 12 中的图像 1,1
    • Refer to the case disassembly guide.
    询问修复机器人
    添加评论
  13. HP Compaq NC6120 CD Drive Replacement: 步骤 13 中的图像 1,1
    • Recommended: First, remove the second RAM chip, in the center of the motherboard. The chip is rectangular, with black squares and a "transcend" label on it.
    询问修复机器人
    添加评论
  14. HP Compaq NC6120 CD Drive Replacement: 步骤 14 中的图像 1,1
    • To remove the chip, locate the two metal clips on the top and bottom of the chip. Clamp them in towards the RAM chip and hold.
    询问修复机器人
    添加评论
  15. HP Compaq NC6120 CD Drive Replacement: 步骤 15 中的图像 1,1
    • Remove the chip by lifting up the side closest to the cd drive first.
    询问修复机器人
    添加评论
  16. HP Compaq NC6120 CD Drive Replacement: 步骤 16 中的图像 1,1
    • Slide the CD drive out to the right.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Keenan
于04/14/15注册
494 声望
创作了2篇指南
团队
Cal Poly, Team 17-4, Forte Spring 2015 Cal Poly, Team 17-4, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G4
3 名成员
创作了6篇指南
2指南评论
16-step guide about an action that can be completed in 3 steps.. REALLY? Why do you make people do SO MANY steps for no reason whatsoever? You REALLY don't need to take apart the whole laptop JUST to remove the optical drive.
Antti Vahtera - 回复 分享
THIS FIXIT GUIDE IS COMPLETELY WRONG.
As Antti Vahtera said, you DO NOT have to disassemble the laptop to remove the CD/DVD. Here are the steps required:
1. Open DVD Tray by pressing button (if switched on) or by pushing a paperclip in the small hole next to button).
2. Turn laptop upside down and open the Memory Cover (one Phillips head screw, then lift off the cover).
3. Remove ONE keybpard screw (Torx or Flat screwdriver) - it’s in the corner of the memory opening, same side as DVD drive.
4. Slide the DVD Drive out by pulling (very little force required). FINISHED !!!!
John Coops - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 2,095
