跳转到主内容
加入维修社区 - 创建账户
HP Compaq 6910p RAM Replacement
你所需要的
    1. HP Compaq 6910p RAM Replacement, RAM: 步骤 1 中的图像 1,2 HP Compaq 6910p RAM Replacement, RAM: 步骤 1 中的图像 2,2
      • Loosen the 1.5 cm Phillips #1 screw.
      • Lift up the cover.
      询问修复机器人
      添加评论
    2. HP Compaq 6910p RAM Replacement: 步骤 2 中的图像 1,3 HP Compaq 6910p RAM Replacement: 步骤 2 中的图像 2,3 HP Compaq 6910p RAM Replacement: 步骤 2 中的图像 3,3
      • Locate the release latches marked in red.
      • Press down on the release latches simultaneously to release the RAM.
      • Remove the RAM.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Tyler Fricks
于10/22/15注册
531 声望
创作了5篇指南
团队
Montana Tech, Team 3-2, Shirk Fall 2015 Montana Tech, Team 3-2, Shirk Fall 2015 的会员
MTUM-SHIRK-F15S3G2
5 名成员
创作了45篇指南
5指南评论
Can The RAM in this machine run with anything more then just 2GB's? I am just wondering.
Marshall WahlstromHelgren - 回复 分享
This laptop can run even 8gb ram (2x4gb), the second slot is under the keyboard.
Zar' Roc - 回复 分享
How many gb of ram should be put in the back….a 4gb  or can an 8gb ram be inserted in the back so you can not have to put any more under the keyboard if you wanted to just upgrade to 8 gb at one time or 4gb at one time and not ever have to buy 2gb, 4gb or 8gb.  answer me at natefoster@bellsouth.net.  I have in my HP6910p  a 2gb ram and a small 60 harddrive and the computer seems to be slow.  Do I need to increase the ram or the harddrive  or both.  Help me with this.  I am waiting too long to start the computer up.  It is a good computer. What should I do to get more speed.
natefoster - 回复 分享
where´s the second slot located?
Patrick Wirth - 回复 分享
It is under the keyboard. There a few youtube videos showing how to remove the keyboard and get to the second slot.
Dynasty - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 53
总计 4,360
