跳转到主内容
加入维修社区 - 创建账户
HP Compaq 6710b Keyboard Replacement
你所需要的
    1. HP Compaq 6710b Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 HP Compaq 6710b Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 HP Compaq 6710b Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
      • Turn off computer before starting.
      • Flip to the backside of the laptop.
      • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
      • Using the same screwdriver, unscrew the 8mm screws.
      • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
      询问修复机器人
      添加评论
    2. HP Compaq 6710b Keyboard Replacement: 步骤 2 中的图像 1,1
      • Flip over the laptop to the top side, and open the laptop.
      • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
      询问修复机器人
      添加评论
    3. HP Compaq 6710b Keyboard Replacement: 步骤 3 中的图像 1,2 HP Compaq 6710b Keyboard Replacement: 步骤 3 中的图像 2,2
      • Using the plastic prying tool, lift the keyboard gently towards you.
      • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
      询问修复机器人
      添加评论
    4. HP Compaq 6710b Keyboard Replacement: 步骤 4 中的图像 1,1
      • Pull up on both sides of the black locking tab of the connector.
      • The keyboard should now be free of the computer.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Khulan Orgil
于04/14/15注册
1,186 声望
创作了6篇指南
团队
Cal Poly, Team 4-2, Maness Spring 2015 Cal Poly, Team 4-2, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G2
4 名成员
创作了54篇指南
2指南评论
No parts required to *replace* the keyboard?
David - 回复 分享
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
Victor Izquierdo Quesada - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 39
总计 5,741
