跳转到主内容
加入维修社区 - 创建账户
HP Chromebook 14-Q010DX Speaker Replacement
你所需要的
    1. HP Chromebook 14-Q010DX Speaker Replacement, Keyboard and Touchpad: 步骤 1 中的图像 1,2 HP Chromebook 14-Q010DX Speaker Replacement, Keyboard and Touchpad: 步骤 1 中的图像 2,2
      • Flip the laptop so the base of the laptop is facing you.
      • Using the #00 screwdriver, unscrew the 13 screws.
      询问修复机器人
      添加评论
    2. HP Chromebook 14-Q010DX Speaker Replacement: 步骤 2 中的图像 1,3 HP Chromebook 14-Q010DX Speaker Replacement: 步骤 2 中的图像 2,3 HP Chromebook 14-Q010DX Speaker Replacement: 步骤 2 中的图像 3,3
      • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
      • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
      询问修复机器人
      添加评论
    3. HP Chromebook 14-Q010DX Speaker Replacement: 步骤 3 中的图像 1,3 HP Chromebook 14-Q010DX Speaker Replacement: 步骤 3 中的图像 2,3 HP Chromebook 14-Q010DX Speaker Replacement: 步骤 3 中的图像 3,3
      • Warning! Handle the flaps and ribbon cables with care to prevent damage.
      • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
      • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
      • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
      询问修复机器人
      添加评论
    4. HP Chromebook 14-Q010DX Speaker Replacement: 步骤 4 中的图像 1,1
      • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
      • The tape has no function other than to keep the wire tucked away.
      询问修复机器人
      添加评论
    5. HP Chromebook 14-Q010DX Speaker Replacement: 步骤 5 中的图像 1,1
      • Set aside the detached keyboard.
      询问修复机器人
      添加评论
    1. HP Chromebook 14-Q010DX Speaker Replacement, Speaker: 步骤 6 中的图像 1,3 HP Chromebook 14-Q010DX Speaker Replacement, Speaker: 步骤 6 中的图像 2,3 HP Chromebook 14-Q010DX Speaker Replacement, Speaker: 步骤 6 中的图像 3,3
      • Undo the black tape located on the bottom from the frame of the laptop.
      • Using fingers or the spudger, slide out the black connector indicated on the left.
      • Use a #00 screwdriver to remove the two screws.
      询问修复机器人
      添加评论
    2. HP Chromebook 14-Q010DX Speaker Replacement: 步骤 7 中的图像 1,2 HP Chromebook 14-Q010DX Speaker Replacement: 步骤 7 中的图像 2,2
      • Gently remove the speakers.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Brandon Nolen
于01/28/15注册
3,536 声望
撰写一个指南
团队
USF Tampa, Team 17-2, Watkins Winter 2015 USF Tampa, Team 17-2, Watkins Winter 2015 的会员
USFT-WATKINS-W15S17G2
4 名成员
创作了56篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 33
总计 1,487
