跳转到主内容
加入维修社区 - 创建账户
HP Chromebook 11 G3 Camera Replacement
你所需要的
    1. HP Chromebook 11 G3 Camera Replacement, Keyboard Mount: 步骤 1 中的图像 1,2 HP Chromebook 11 G3 Camera Replacement, Keyboard Mount: 步骤 1 中的图像 2,2
      • Flip the laptop upside down so that the lid lies flat on the table.
      • Remove the nine 6mm Phillips #00 screws that line the border.
      询问修复机器人
      添加评论
    2. HP Chromebook 11 G3 Camera Replacement: 步骤 2 中的图像 1,2 HP Chromebook 11 G3 Camera Replacement: 步骤 2 中的图像 2,2
      在这个步骤中使用的工具:
      • Remove the two rubber feet closest to the hinge using tweezers.
      • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
      • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
      询问修复机器人
      添加评论
    3. HP Chromebook 11 G3 Camera Replacement: 步骤 3 中的图像 1,1
      • Flip the laptop so it is in the upright position.
      • Open the lid.
      • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
      • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
      询问修复机器人
      添加评论
    4. HP Chromebook 11 G3 Camera Replacement: 步骤 4 中的图像 1,3 HP Chromebook 11 G3 Camera Replacement: 步骤 4 中的图像 2,3 HP Chromebook 11 G3 Camera Replacement: 步骤 4 中的图像 3,3
      • Tilt the keyboard mount up.
      • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
      • Gently remove both ribbon cables.
      添加评论
    5. HP Chromebook 11 G3 Camera Replacement: 步骤 5 中的图像 1,1
      • Lift the keyboard mount out of the laptop.
      询问修复机器人
      添加评论
    1. HP Chromebook 11 G3 Camera Replacement, Display Assembly: 步骤 6 中的图像 1,1
      • Gently tug on the black and white wires connected to the Wi-Fi module to disconnect them.
      询问修复机器人
      添加评论
    2. HP Chromebook 11 G3 Camera Replacement: 步骤 7 中的图像 1,2 HP Chromebook 11 G3 Camera Replacement: 步骤 7 中的图像 2,2
      • Using a spudger, lift the ZIF retaining flap that secures the display’s ribbon cable to the motherboard.
      • Gently pull the ribbon cable out of its socket.
      询问修复机器人
      添加评论
    3. HP Chromebook 11 G3 Camera Replacement: 步骤 8 中的图像 1,1
      • Free the wire from the casing.
      询问修复机器人
      添加评论
    4. HP Chromebook 11 G3 Camera Replacement: 步骤 9 中的图像 1,1
      • Remove the two 6mm Phillips #00 screws located near the upper left and right corners of the hinge mounts.
      • Hold the lid so that it is folded slightly inwards while removing the screws so that the lid doesn’t fall.
      询问修复机器人
      添加评论
    5. HP Chromebook 11 G3 Camera Replacement: 步骤 10 中的图像 1,1
      • Rotate the lid to a 90-degree angle with the table.
      • Shimmy the lid out of the laptop.
      询问修复机器人
      添加评论
    1. HP Chromebook 11 G3 Camera Replacement, Screen Bezel: 步骤 11 中的图像 1,3 HP Chromebook 11 G3 Camera Replacement, Screen Bezel: 步骤 11 中的图像 2,3 HP Chromebook 11 G3 Camera Replacement, Screen Bezel: 步骤 11 中的图像 3,3
      • Use the plastic opening tool to pry the left and right side of the top of the lid, and proceed inwards from the sides.
      • Do not attempt to remove the entire frame; this isn't necessary for removing the camera.
      • Do not pry at the center of the lid; this may damage the camera inside.
      询问修复机器人
      添加评论
    1. HP Chromebook 11 G3 Camera Replacement, Camera: 步骤 12 中的图像 1,1
      • Gently remove the slide-out connector near the bottom left corner of the camera mount.
      询问修复机器人
      添加评论
    2. HP Chromebook 11 G3 Camera Replacement: 步骤 13 中的图像 1,1
      在这个步骤中使用的工具:
      • Locate the two silver strips of tape on each edge of the camera mount.
      • Use tweezers to peel off these strips.
      询问修复机器人
      添加评论
    3. HP Chromebook 11 G3 Camera Replacement: 步骤 14 中的图像 1,1
      • Use a plastic opening tool to pry the camera mount out of the lid.
      • Apply force evenly to prevent bending the mount.
      询问修复机器人
      添加评论
    4. HP Chromebook 11 G3 Camera Replacement: 步骤 15 中的图像 1,1
      • Lift the camera out of the lid.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Rahul Goyal
于04/26/17注册
1,401 声望
创作了10篇指南
团队
Cal Poly, Team S23-G3, Livingston Spring 2017 Cal Poly, Team S23-G3, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G3
4 名成员
创作了72篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 1,474
