跳转到主内容
加入维修社区 - 创建账户
HP 7 1800 Front Facing Camera Replacement
你所需要的
    1. HP 7 1800 Front Facing Camera Replacement, Remove the back panel: 步骤 1 中的图像 1,2 HP 7 1800 Front Facing Camera Replacement, Remove the back panel: 步骤 1 中的图像 2,2
      • Carefully insert a Spudger into one of the corners of the tablet.
      • Slide the Spudger along the edge popping the tabs out along the way.
      • Be careful not to break the tabs.
      询问修复机器人
      添加评论
    2. HP 7 1800 Front Facing Camera Replacement, Remove the battery: 步骤 2 中的图像 1,3 HP 7 1800 Front Facing Camera Replacement, Remove the battery: 步骤 2 中的图像 2,3 HP 7 1800 Front Facing Camera Replacement, Remove the battery: 步骤 2 中的图像 3,3
      在这个步骤中使用的工具:
      • Slide the Spudger under the battery to lift it off the adhesive.
      • Gently pull the cable connection from the motherboard using tweezers.
      询问修复机器人
      添加评论
    1. HP 7 1800 Front Facing Camera Replacement, Remove the large ribbon cable: 步骤 3 中的图像 1,2 HP 7 1800 Front Facing Camera Replacement, Remove the large ribbon cable: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
      询问修复机器人
      添加评论
    2. HP 7 1800 Front Facing Camera Replacement, Remove the smaller ribbon cable: 步骤 4 中的图像 1,2 HP 7 1800 Front Facing Camera Replacement, Remove the smaller ribbon cable: 步骤 4 中的图像 2,2
      • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
      询问修复机器人
      添加评论
    3. HP 7 1800 Front Facing Camera Replacement, Unscrew the 7 silver screws from the logic board: 步骤 5 中的图像 1,1
      • Remove the following 7 screws:
      • Six 4.17mm Phillips #00 around the motherboard.
      • One 2.67mm Phillips #00 next to the front facing camera.
      • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
      询问修复机器人
      添加评论
    4. HP 7 1800 Front Facing Camera Replacement, Unplug the front facing camera from the logic board: 步骤 6 中的图像 1,1
      • Gently pry the front facing camera plug up and off of the motherboard.
      询问修复机器人
      添加评论
    5. HP 7 1800 Front Facing Camera Replacement, Remove the logic board: 步骤 7 中的图像 1,1
      • Carefully lift the motherboard directly up.
      询问修复机器人
      添加评论
    1. HP 7 1800 Front Facing Camera Replacement, Remove the ribbon cable attached to the metal plate: 步骤 8 中的图像 1,2 HP 7 1800 Front Facing Camera Replacement, Remove the ribbon cable attached to the metal plate: 步骤 8 中的图像 2,2
      • On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
      询问修复机器人
      添加评论
    2. HP 7 1800 Front Facing Camera Replacement, Unscrew the 7 black screws on the metal plate: 步骤 9 中的图像 1,1
      • Unscrew the following black screws:
      • Seven 2.82mm Phillips #00 around the metal casing.
      询问修复机器人
      添加评论
    3. HP 7 1800 Front Facing Camera Replacement, Remove the metal plate: 步骤 10 中的图像 1,1
      • Gently lift the metal plate directly up.
      询问修复机器人
      添加评论
    4. HP 7 1800 Front Facing Camera Replacement, Remove the camera: 步骤 11 中的图像 1,1
      在这个步骤中使用的工具:
      • Gently remove the camera from the device with tweezers by lifting it up and out of its square hole.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Trevor Shumate
于01/21/15注册
225 声望
创作了2篇指南
团队
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 的会员
USFT-BROWN-W15S4G1
4 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 28
总计 563
